DNSmasq PXE Boot
Krusty_47
I am running Merlin build 3.0.0.4.374.34_2
I am attempting to setup PXE boot to Windows deployment services.
I am having issues accessing jffs. when I try to go to the /jffs directory I get permission denied.
I have turned on jffs, formatted upon reboot and rebooted twice. No change.
I've done a decent amount of searching but haven't found anything. Is there a quick walk through on how to set this up?
Any help would be greatly appreciated.
What router model? Any error message in syslog after the reboot regarding the JFFS partition?
Post the output of this command after a reboot:
nvram show | grep jffs
N66R
jffs2_on=1
jffs2_exec=
jffs2_size=6291456
jffs2_format=0
size: 42652 bytes (22884 left)
No errors that I can see in the sys log.
Won't work. dnsmasq's TFTP server can't remap some symbols. Please use tftpd-hpa from Entware with following remapping file:
$ cat /opt/etc/tftpd/remap
r       ^\\             # Remove first double backslashes
rg      \\      /       # Convert backslashes to slashes
#e      pxeboot.n12      # Do not proces subsequent rules
Full Win7 network deployment guide is available in russian only. May be I should to post it here (in english of course)?
I'm just trying to put in the DHCP option IE dhcp-boot=pxelinux.0,,192.168.1.10
Just for my particular setup. Although I can't access jffs or the dnsmasq.conf file to add it.
N66R
jffs2_on=1
jffs2_exec=
jffs2_size=6291456
jffs2_format=0
Try the following:
nvram unset jffs2_size
nvram set jffs2_format=1
nvram commit
reboot
Still getting the same permission denied with the following
jffs2_on=1
jffs2_exec=
jffs2_size=6291456
jffs2_format=0
jffs2_on=1
jffs2_exec=
jffs2_size=6291456
jffs2_format=0
Are these the result after you ran the commands I gave you?
Yes I ran what you gave me then rebooted. Getting the exact same info and error as before.
Then it means the router did reformat the jffs partition properly. If it's not mounted and there is nothing in the system log then I have no idea what would be going on.
