Dnsmasq returns 10.0.0.1
asz007
Hello everyone,
I have an RT-N66U router with the Asuswrt Merlin firmware. I am using the router in repeater mode, and at the same time I want the router to function as a DNS server as well. I have setup dnsmasq with the following dnsmasq.conf
#########beginning of file##########
pid-file=/var/run/dnsmasq.pid
user=nobody
bind-dynamic
interface=br0
no-dhcp-interface=br0
no-negcache
cache-size=1500
min-port=4096
domain-needed
bogus-priv
no-resolv
no-poll
server=/lan/192.168.1.2
server=8.8.8.8
server=8.8.4.4
local=/lan/
no-hosts
addn-hosts=/jffs/configs/static_hosts.txt
expand-hosts
domain=lan
#########end of file#####
The content of static_hosts.txt is just the following line
192.168.1.5 test
Now, everything works fine when I am logged in to the router via SSH and issue the following command:
nslookup test 192.168.1.2
I get a correct response i.e..
Server: 192.168.1.2
Address 1: 192.168.1.2 RT-N66U-9698.
Address 1: 192.168.1.5 test.lan
But when I issue the same command from my Mac:
The name cannot be resolved, i.e. I get the following response:
Server: 192.168.1.2
Address: 192.168.1.2#53
Address: 10.0.0.1
I have disabled the "browser redirect notice" from the Asus Web Gui, but to no avail, so here I am! Any help in solving this is appreciated!
Your router is in repeater mode, it cannot function as a DNS Server and be a repeater at the same time.
@thelonelycoder Thanks for the reply. I suspected this also, but curious to know why it would work perfectly when I am ssh:ed into the router, but not from another device on lan?
Because all DNS and DHCP queries are handled by the router, not the repeater.
The repeater may answer to local ping requests though but I am not sure.
Dnsmasq is only active when the device is in Wireless Router Mode, all other modes have it disabled.
What is your upstream router (that the repeater is linked to)? Does that also have "browser redirect notice" disabled?
EDIT: What happens if you do a lookup on a FQDN that isn't part of the .lan domain, i.e. google.com?
