binarydad
I upgraded from a AC68U to a AX86U today. So far it's performing really well, but wanted to confirm if there is anything in the logs that I should address. I've gotten used to certain expected log entries in my old router, so since I'm seeing new ones, I'm not sure if they're normal/expected or are a concern.
Specifically, the
is the only error I see being logged intermittently. There's also entries that reference RADIUS (which I'm not using since I'm WPA2/Personal)
Pastebin of logs: https://go.binarydad.com/ax86ulogs
Thanks!
Specifically, the
Specifically, the `dnsmasq-script[1518]: json_object_from_file: error opening file /jffs/nmp_vc_json.js: No such file or directory` is the only error I see being logged intermittently. There's also entries that reference RADIUS (which I'm not using since I'm WPA2/Personal)
Thanks!
