Does Entware survive firmware upgrades?
s_Fanous
I'm planning to upgrade the firmware on my router and even though I've done this a few times before I had never previously done this with Entware setup and multiple packages installed. I guess my question is following the upgrade will
  1. Entware and installed packages on USB continue to function normally?
  2. Do I have to do a fresh Entware install and reinstall all packages?
  3. Is it possible to backup and then restore Entware?
TIA
Entware won't be affected by a firmware upgrade, however make sure you keep a backup of the JFFS partition, especially if you have an RT-N66U, as there is a chance that the scripts related to Entware might be lost in the upgrade.
