Does my iptables looks normal?
NoBenefit
I have RT-AX86U using 388.2_2, lately it's been acting weird, and I don't have much experiences with iptables, I do not have WAN access enabled, nor any kind of remote access enabled, I’m using it with Tmobile gateway thru wan port.
Today the swap gone, and scribe said usb drive is bad, and some how my window computer see two 5Ghz wifi but not Mac or iPhone, one with correct name and one with weird characters, guest wifi is not enabled.
-P INPUT ACCEPT
-P FORWARD ACCEPT
-P OUTPUT ACCEPT
-N ACCESS_RESTRICTION
-N DNSFILTER_DOT
-N FUPNP
-N IControls
-N INPUT_ICMP
-N INPUT_PING
-N IPSEC_DROP_SUBNET_ICMP
-N IPSEC_STRONGSWAN
-N OUTPUT_DNS
-N OUTPUT_IP
-N OVPNCF
-N OVPNCI
-N OVPNSF
-N OVPNSI
-N PControls
-N PTCSRVLAN
-N PTCSRVWAN
-N SECURITY
-N VPNCF
-N VPNCI
-N WGCF
-N WGCI
-N WGNPControls
-N WGSF
-N WGSI
-N default_block
-N logaccept
-N logdrop
-N logdrop_dns
-N logdrop_ip
-A INPUT -p icmp -m icmp --icmp-type 8 -j INPUT_PING
-A INPUT -m state --state RELATED,ESTABLISHED -j logaccept
-A INPUT -m state --state INVALID -j logdrop
-A INPUT ! -i br0 -j PTCSRVWAN
-A INPUT -i br0 -j PTCSRVLAN
-A INPUT ! -i lo -p tcp -m tcp --dport 5152 -j logdrop
-A INPUT -i br0 -m state --state NEW -j ACCEPT
-A INPUT -i lo -m state --state NEW -j ACCEPT
-A INPUT -p udp -m udp --sport 67 --dport 68 -j logaccept
-A INPUT -p icmp -j INPUT_ICMP
-A INPUT -j WGSI
-A INPUT -j WGCI
-A INPUT -j OVPNSI
-A INPUT -j OVPNCI
-A INPUT -j logdrop
-A FORWARD -j IPSEC_DROP_SUBNET_ICMP
-A FORWARD -j IPSEC_STRONGSWAN
-A FORWARD -m state --state RELATED,ESTABLISHED -j logaccept
-A FORWARD -j WGSF
-A FORWARD -j OVPNSF
-A FORWARD ! -i br0 -o eth0 -j logdrop
-A FORWARD -i br0 -o br0 -j logaccept
-A FORWARD -m state --state INVALID -j logdrop
-A FORWARD -m conntrack --ctstate DNAT -j logaccept
-A FORWARD -j WGCF
-A FORWARD -j OVPNCF
-A FORWARD -j VPNCF
-A FORWARD -i br0 -j ACCEPT
-A FORWARD -j logdrop
-A OUTPUT -p udp -m udp --dport 53 -m u32 --u32 "0x0>>0x16&0x3c@0x8>>0xf&0x1=0x0" -j OUTPUT_DNS
-A OUTPUT -p tcp -m tcp --dport 53 -m u32 --u32 "0x0>>0x16&0x3c@0xc>>0x1a&0x3c@0x8>>0xf&0x1=0x0" -j OUTPUT_DNS
-A OUTPUT -j OUTPUT_IP
-A INPUT_ICMP -p icmp -m icmp --icmp-type 8 -j RETURN
-A INPUT_ICMP -p icmp -m icmp --icmp-type 13 -j RETURN
-A INPUT_ICMP -p icmp -j logaccept
-A INPUT_PING -i eth0 -p icmp -j logdrop
-A OUTPUT_DNS -m string --hex-string "|10706f697579747975696f706b6a666e6603636f6d00|" --algo bm --to 65535 --icase -j logdrop_dns
-A OUTPUT_DNS -m string --hex-string "|0d72666a656a6e666a6e65666a6503636f6d00|" --algo bm --to 65535 --icase -j logdrop_dns
-A OUTPUT_DNS -m string --hex-string "|1131306166646d617361787373736171726b03636f6d00|" --algo bm --to 65535 --icase -j logdrop_dns
-A OUTPUT_DNS -m string --hex-string "|0f376d667364666173646d6b676d726b03636f6d00|" --algo bm --to 65535 --icase -j logdrop_dns
-A OUTPUT_DNS -m string --hex-string "|0d386d617361787373736171726b03636f6d00|" --algo bm --to 65535 --icase -j logdrop_dns
-A OUTPUT_DNS -m string --hex-string "|0f3966646d617361787373736171726b03636f6d00|" --algo bm --to 65535 --icase -j logdrop_dns
-A OUTPUT_DNS -m string --hex-string "|1265666274686d6f6975796b6d6b6a6b6a677403636f6d00|" --algo bm --to 65535 --icase -j logdrop_dns
-A OUTPUT_DNS -m string --hex-string "|086861636b7563647403636f6d00|" --algo bm --to 65535 --icase -j logdrop_dns
-A OUTPUT_DNS -m string --hex-string "|076c696e77756469056633333232036e657400|" --algo bm --to 65535 --icase -j logdrop_dns
-A OUTPUT_DNS -m string --hex-string "|0f6c6b6a68676664736174727975696f03636f6d00|" --algo bm --to 65535 --icase -j logdrop_dns
-A OUTPUT_DNS -m string --hex-string "|0b6d6e627663787a7a7a313203636f6d00|" --algo bm --to 65535 --icase -j logdrop_dns
-A OUTPUT_DNS -m string --hex-string "|077131313133333303746f7000|" --algo bm --to 65535 --icase -j logdrop_dns
-A OUTPUT_DNS -m string --hex-string "|057371353230056633333232036e657400|" --algo bm --to 65535 --icase -j logdrop_dns
-A OUTPUT_DNS -m string --hex-string "|077563746b6f6e6503636f6d00|" --algo bm --to 65535 --icase -j logdrop_dns
-A OUTPUT_DNS -m string --hex-string "|0e7a786376626d6e6e666a6a66777103636f6d00|" --algo bm --to 65535 --icase -j logdrop_dns
-A OUTPUT_DNS -m string --hex-string "|0a65756d6d6167766e627003636f6d00|" --algo bm --to 65535 --icase -j logdrop_dns
-A OUTPUT_DNS -m string --hex-string "|0b726f75746572736173757303636f6d00|" --algo bm --to 65535 --icase -j logdrop_dns
-A OUTPUT_DNS -m string --hex-string "|037777770b726f757465722d6173757303636f6d00|" --algo bm --to 65535 --icase -j logdrop_dns
-A OUTPUT_DNS -m string --hex-string "|0377777709617375736c6f67696e03636f6d00|" --algo bm --to 65535 --icase -j logdrop_dns
-A OUTPUT_DNS -m string --hex-string "|0d72657065617461722d6173757303636f6d00|" --algo bm --to 65535 --icase -j logdrop_dns
-A OUTPUT_DNS -m string --hex-string "|037777310b726f757465722d6173757303636f6d00|" --algo bm --to 65535 --icase -j logdrop_dns
-A OUTPUT_IP -d 193.201.224.0/24 -j logdrop_ip
-A OUTPUT_IP -d 51.15.120.245/32 -j logdrop_ip
-A OUTPUT_IP -d 45.33.73.134/32 -j logdrop_ip
-A OUTPUT_IP -d 190.115.18.28/32 -j logdrop_ip
-A OUTPUT_IP -d 51.159.52.250/32 -j logdrop_ip
-A OUTPUT_IP -d 190.115.18.86/32 -j logdrop_ip
-A SECURITY -p tcp -m tcp --tcp-flags FIN,SYN,RST,ACK SYN -m limit --limit 1/sec -j RETURN
-A SECURITY -p tcp -m tcp --tcp-flags FIN,SYN,RST,ACK SYN -j logdrop
-A SECURITY -p tcp -m tcp --tcp-flags FIN,SYN,RST,ACK RST -m limit --limit 1/sec -j RETURN
-A SECURITY -p tcp -m tcp --tcp-flags FIN,SYN,RST,ACK RST -j logdrop
-A SECURITY -p icmp -m icmp --icmp-type 8 -m limit --limit 1/sec -j RETURN
-A SECURITY -p icmp -m icmp --icmp-type 8 -j logdrop
-A SECURITY -j RETURN
-A logaccept -m state --state NEW -j LOG --log-prefix "ACCEPT " --log-tcp-sequence --log-tcp-options --log-ip-options
-A logaccept -j ACCEPT
-A logdrop -m state --state NEW -j LOG --log-prefix "DROP " --log-tcp-sequence --log-tcp-options --log-ip-options
-A logdrop -j DROP
-A logdrop_dns -j LOG --log-prefix "DROP_DNS " --log-tcp-sequence --log-tcp-options --log-ip-options
-A logdrop_dns -j DROP
-A logdrop_ip -j LOG --log-prefix "DROP_IP " --log-tcp-sequence --log-tcp-options --log-ip-options
-A logdrop_ip -j DROP
