HarryMuscle
Does anyone know if the TX Power setting from the WiFi Professional settings page syncs to AiMesh nodes? In other words, if I reduce the TX power from the default full power will the nodes also reduce their power? If not, is there any way to sync these settings via a script?
I will be running a RT-AX86U as the main router with a RT-AX86S node. Both running 386.7_2 Merlin firmware.
Thanks,
Harry
Thanks,
Harry
