Domain-based VPN Routing Script
return on empty, both before and after, so it break somewhere even without reboot the device. I just play with few hours and just notice that it didn't engage. This only happen to the AC86U, so it might be device relate?
Can you send me the full script you have in openvpn-event?
Also if you manually run
/jffs/scripts/domain_vpn_routing.sh cron
does it create the cron job in
cru l
cru l
openvpn-event
sh /jffs/scripts/domain_vpn_routing.sh cron # domain_vpn_routing
sh /jffs/scripts/domain_vpn_routing.sh querypolicy all # domain_vpn_routing_queryall
cru l
show up empty.
I usually do
crontab -l
command and it did show one line before when I first use it. */5 * * * * ......
Now nothing
openvpn-event
cru l
show up empty.
I usually do
crontab -l
Now nothing
openvpn-event
cru l
show up empty.
I usually do
crontab -l
Now nothing
Well that would explain why your cronjobs aren't creating? What model and firmware are you using? Also when you run openvpn-event does it perform the querypolicy all for you?
AC68U 386.5_2
AC86U 387.Beta1
Internet source is a hotspot Franklin T9 on both
purpose is bypass streaming throttling
how do I run the openvpn-event?
looking at the Log
ovpn-client2[2573]: RESOLVE: Cannot resolve host address: xxxxxx.xxxxxx.xxx:xxxx (Temporary failure in name resolution)
maybe because this?
AC68U 386.5_2
AC86U 387.Beta1
looking at the Log
maybe because this?
Just execute it in the command console.
/jffs/scripts/openvpn-event
-sh: /jffs/scripts/openvpn-event: Permission denied
Was your openvpn-event script created during the install of my script? It should set the permission for it if so, it appears it was created prior to install and it does not have the correct permissions to run. Set the permission to allow it be executed with this command.
chmod 755 /jffs/scripts/openvpn-event
I think it create with the script I didn't ssh until I'm playing with your script.
speekkong@RT-AC68U-DFE0:/tmp/home/root# /jffs/scripts/openvpn-event
: not foundts/openvpn-event: line 1:
domain_vpn_routing.sh - Cron Job
crontab: can't open 'speekkong': No such file or directory
Creating cron jobs...
Completed creating cron job.
: not foundts/openvpn-event: line 3:
domain_vpn_routing.sh - Query Policy
Ah I see the problem....yea I forgot to add in the step for it to create the script...it created it by adding the lines, I will fix in a patch. You should be good by adding this to the top line of the script.
#!/bin/sh
v1.1-beta Release: To use the beta use the following command to replace your production version of the script.
/usr/sbin/curl -s "https://raw.githubusercontent.com/Ranger802004/asusmerlin/main/domain_vpn_routing/domain_vpn_routing_v1.1-beta.sh" -o "/jffs/scripts/domain_vpn_routing.sh" && chmod 755 /jffs/scripts/domain_vpn_routing.sh
To revert back to production release:
/jffs/scripts/domain_vpn_routing.sh update
Release Notes:
v1.1-beta
- Added logic during install to create openvpn-event if it doesn't exist.
- Added warning message when executing querypolicy if it is already currently running.
#!/bin/sh
Very weird after adding
-sh: /jffs/scripts/openvpn-event: not found
the script is there, but say not found. Remove the line it work and same output like before.
Try deleting openvpn-event and recreate it by running the install command from my script. It should leave your existing policy data alone.
yup just did that and it did create a duplicate line again.
Duplicate where? Is it executing openvpn-event now?
EDIT:
I meant to specify using the new v1.1-beta release I just published for running install.
EDIT:
yup using your newest v1.1-beta, del the openvpn-event, re-run install,
openvpn-event
#!/bin/sh
openvpn-event
#!/bin/sh
I see why's it doing that now...I will correct that but it should be harmless. If you run openvpn-event does it properly execute now?
EDIT: I modified the v1.1-beta release (Quick fix) to remedy this issue. Just delete the middle entry and should be good now.
Yes, it work other than line 2,4,6 not foundts. I'm gonna test for few hours then reboot to see if all stick.
That's strange...that's coming from your openvpn-event execution?
Yeah, but I think it because the line are blank?
: not foundts/openvpn-event: line 2:
: not foundts/openvpn-event: line 4:
: not foundts/openvpn-event: line 6:
That shouldn't matter, I have spaces in mine and it executes fine. Send me the full output of your openvpn-event script please. Also what version and firmware are you on?
