CaptainSTX
Part of the Furniture
Recently I no longer could stream Amazon Prime video on my smart TVs and Roku devices. The error message was that the TV or device was not connected to the internet. Not accurate as Netflix, YouTube, etc. were all working fine. Made no difference if the device was connected by Ethernet or Wi-Fi to the LAN.
Apparently, Amazon determines if it is connected by trying to contact a DNS server coded into the application's firmware. As I was using DOT this attempt to check for connectivity failed. Once I enabled the DNS Director, input the device's MAC for each streaming device and selected 8.8.8.8 as the DNS for these devices the problem went away.
As time permits, I plan to try this for other problematic IoT devices including my Amazon Spots.
There are probably other things that could be done such as not using DOT or changing the most restrictive DOT settings which would accomplish the same thing but for those individuals having problem connecting various devices to their network it is another possible solution that can be tried.
