DoT on 86u
maxsteel
Hello,
Is it possible to setup Cloudflare as DNS over TLS on 86u router with Merlin firmware? if so how please?
Thanks,
Hello,
Thanks,
Check/Search for Unbound maybe that can work, Dont think Stubby installer works with the 86u yet
Hello,
Thanks,
I proposed how I'd like to see it with DNSFilter to force Cloudflare DoH and/or DoT on local cients here
https://www.snbforums.com/threads/question-about-dns-filtering.47739/#post-446236
and more clear starting here:
https://www.snbforums.com/threads/question-about-dns-filtering.47739/#post-446245
I envision having the Global Filter Mode option Cloudflare HTTPS (or 1.1.1.1 HTTPS) listed/available with those other 5 options currently there. The router code handles HTTPS required with Cloudflare's servers. Maybe TLS option as well but probably only need one.
So, the local network clients wouldn't change anything, the router admin simply would select Cloudflare HTTPS under DNSFilter Global Filter Mode. Cloudflare's servers are public and free so don't need to have an account and DNSOMatic with OpenDNS.
I'd be fine with a Cloudflare TLS | Cloudflare DoT option instead of a HTTPS / DoH option. Firefox only supports HTTPS but I didn't even realize the 1.1.1.1 android app supports both.
I'll read up on why DoT may be better and switch accordingly.
Regardless, the router would handle this. The local client's would be configured as they are now with the router intercepting the requests (except the phones/tablets running the 1.1.1.1 app).
opkg remove stubby --autoremove
opkg install /path/getdns_1.5.0-tls1.3_aarch64-3.10.ipk
opkg install /path/stubby_0.2.4-tls1.3_aarch64-3.10.ipk
opkg install fake-hwclock haveged
nano /opt/etc/init.d/S61stubby
#!/bin/sh
ENABLED=yes
PROCS=stubby
ARGS="-C /opt/etc/stubby/stubby.yml"
PREARGS="nohup"
DESC=$PROCS
PATH=/opt/sbin:/opt/bin:/opt/usr/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
. /opt/etc/init.d/rc.func
chmod 755 /opt/etc/init.d/S61stubby
nano /opt/etc/stubby/stubby.yml
#NOTE: See '/etc/stubby/stubby.yml.default' for original config file and descriptions
resolution_type: GETDNS_RESOLUTION_STUB
dns_transport_list:
  - GETDNS_TRANSPORT_TLS
tls_authentication: GETDNS_AUTHENTICATION_REQUIRED
tls_min_version: GETDNS_TLS1_3
tls_ciphersuites: "TLS_AES_128_GCM_SHA256:TLS_AES_256_GCM_SHA384:TLS_CHACHA20_POLY1305_SHA256"
tls_query_padding_blocksize: 128
edns_client_subnet_private : 1
round_robin_upstreams: 1
idle_timeout: 10000
listen_addresses:
  - 127.0.0.1@5453
#  -  0::1@5453
upstream_recursive_servers:
# IPv6 addresses
# # Cloudflare IPv6
#  - address_data: 2606:4700:4700::1111
#    tls_auth_name: "cloudflare-dns.com"
# # Quad 9 IPv6
#  - address_data: 2620:fe::10
#    tls_auth_name: "dns.quad9.net"
# IPv4 addresses
# # Cloudflare servers
  - address_data: 1.1.1.1,
  - address_data: 1.0.0.1,
# Quad 9 service
#  - address_data: 9.9.9.10
nano /jffs/configs/dnsmasq.conf.add
no-resolv
server=127.0.0.1#5453
chmod +x /jffs/configs/dnsmasq.conf.add
echo "cru a SaveSystemTime \"0 * * * * /opt/bin/fake-hwclock\"" >> /jffs/scripts/services-start
cru a SaveSystemTime "0 * * * * /opt/bin/fake-hwclock"
/opt/etc/init.d/S01fake-hwclock stop
/opt/etc/init.d/S02haveged start
/opt/etc/init.d/S61stubby start
service restart_dnsmasq
WAN -> Internet Connection -> WAN DNS Setting
Connect to DNS Server automatically -> No
DNS Server1 -> blank
DNS Server2 -> blank
opkg install stubby fake-hwclock
opkg install /path/getdns_1.4.2-1a_aarch64-3.10.ipk
So I tried above and I get this:
@RT-AC86U-99A8:/tmp/home/root# opkg install /path/getdns_1.4.2-1a_aarch64-3.10.ipk
Collected errors:
 * wfopen: /path/getdns_1.4.2-1a_aarch64-3.10.ipk: No such file or directory.
 * pkg_init_from_file: Failed to extract control file from /path/getdns_1.4.2-1a_aarch64-3.10.ipk.
Any idea what I am doing wrong. Again, I installed Stubby first and now I am following these steps to apply the patch. Was able to add all other steps with no issues.
Thank you
Keep in mind that the resolver test for DNSSEC only tests that the resolver you use is able to do DNSSEC. Cloudflare has a test for DoT and DoH but as soon as you add DNSSEC the test fails.
The Stubby add on with Merlin DNSSEC is working well for me with Cloudflare. Cleanbrowsing resolvers also seem to work well. Mixed results with others.
Sent from my SM-T380 using Tapatalk
Tried to install it for the second time in my AC86U and still failed. Used the original instructions and he patch ones but still not able to start Stubby. The internet stops and on the WAN tab the router IP is inserted under DNS 1. I understand that Stubby is doing this somehow.
Also, downloading the getdns package does not work from above command. I am thinking that is why my install is not going as expected.
Steps I followed:
1. Installed Stubby by using the original curl per @Xentrk. This stops my internet completely and the Network Map shows my internet status as Disconnected.
2. I completely uninstalled/wiped out my VPN profiles thinking that this was the culprit but didn’t help out at all.
3. Then tried to install the patch for Stubby using @Odkrys instructions but then I realized that I had to have an internet connection in order to download Stubby packages.
4. This forced me to wipe out my router’s IP from the WAN tab and include Cloudflaire’s DNS servers there instead.
5. Now I have internet connection established I was able to install fake-hwclock as described via above command but not the getdns one. See my previous post on the error that I get when I try to install that.
6. Was able to follow the other steps in the patch installation but when attempting to see if Stubby is working by using the “check” command I get the: Stubby........dead.
7. Uninstalled Stubby using the initial curl and reinstalled it again but no success. Going back to DNSCrypt and installed my VPN client config. Everything is working just fine now.
Unless someone is willing to re-write the entire installation guide using the original instructions and those from the patch in a very clear, step-by-step and thorough steps, I guess I will have to wait until there is a more complete script to install Stubby in AC86U in the future.
path mean location of ipk file lol.
e.g.) opkg install /opt/getdns_1.4.2-1a_aarch64-3.10.ipk
opkg install /mnt/sda1/~~~~/getdns_1.4.2-1a_aarch64-3.10.ipk
Got ya! Thank you!
To clarify....after a successful installation of Stubby, do the DNS settings stay as:
DNS 1 = router’s IP
DNS = null ?
And does such WAN DNS setup cause any interference with Diversion (more specifically pixelserve) since the latter uses xxx.xxx.xx.2 as an IP?
DNS 1 = router’s IP
DNS = null ?
Are you meaning DNS settings in LAN tab?
LAN DNS push specific dns server to clients if you set it. Normally it doesn't need to change.
WAN DNS should be null.
No idea about Diversion, maybe it will not interfere it.
No, the DNS settings under the WAN tab (Automatically connect to the DNS servers Yes or No).
When I install Stubby using the original curl, it automatically places my router’s IP on one of the DNS IP spaces under the WAN tab and my internet stops completely. Whereas the second space is null.
But then do I leave this “Automatically connect to DNS” setting as Yes or No?
Check the time on your router. Stubby will not allow the time to sync on router start. Fix this by using a time server IP address in lieu of a URL or the fix Skeal came up with.
