D
Deleted member 62525
Guest
I thought I post this topic since we had few DNS changes and new functionality added to the firmware 384.12 and 384.13.
Below is the configuration example (my own setup on RT-86U).
1. WAN DNS section DNSSEC is enabled
2. WAN DNS DoT is enabled in Strict mode using Quad1 and Quad2 DNS servers.
3. OpenVPN Client DNS is set to Strict mode. In addition vpn configration section has entry dhcp-option DNS <vpn dns IP>
4. VPN Policy has all clients using VPN except the smartTV using WAN.
With above configuration for both WAN and VPN Client - 2 separate DNS sets, I have noticed that when I perform DNS test leak on my VPN clients they all use WAN DoT DNS and not VPN DNS.
Switching VPN DNS to Exclusive make VPN clients to use VPN DNS, but at this point Diversion cannot work.
In previous versions of the firmware VPN DNS Strict mode worked without issues even when I used Stubby on the command line to have DoT working. So, my question is if this new behavior is by design/intended or its a bug? It well could by my config in some way is interfering with the setup. Can anyone confirm this?
I tried resetting the router, cleared NVRAM, re-do the setup but still getting the same results.
My objective is to have all VPN clients use VPN DNS and Diversion working, while non-vpn clients use WAN DoT DNS servers.
