Lynx
I have the following setup:
ASUS RT-AX86U (192.168.1.1) -> Huawei 4G Modem (192.168.8.1)
[Huawei 4G Modem connected to WAN port of ASUS Router]
I have found that the only way I seem to be able to get my ASUS Router to pick up a WAN IP from my Huawei 4G Modem is to ensure that I set my Huawei 4G Modem DHCP mode to: ON before I set the Huawei 4G Modem to Bridge Mode: ON. Unless I do this then my ASUS Router does not pick up a WAN IP address.
My Huawei 4G Modem connects to an ISP that employs CG-NAT.
But I am trying to avoid at least the double NAT scenario as between my ASUS Router and Huawei 4G Modem.
The tests below confuse me.
In the first scenario, with VPN OFF, it looks like my Huawei 4G Modem is NOT operating in bridge mode.
In second second test scenario, with VPN ON, it looks like my Huawei 4G Modem IS operating in bridge mode.
Now when I run tracert 8.8.8.8 with VPN OFF I see:
Any help much appreciated with this confusion!
When I run tracert 8.8.8.8 with VPN ON I see:tracert 8.8.8.8
Tracing route to dns.google [8.8.8.8]
over a maximum of 30 hops:
1 1 ms <1 ms <1 ms RT-AX86U-4168 [192.168.1.1]
2 2 ms 1 ms 1 ms 192.168.8.1
3 * * * Request timed out.
4 48 ms 51 ms 45 ms 192.168.213.21
5 43 ms 47 ms 47 ms 192.168.213.22
6 * * * Request timed out.
7 * * * Request timed out.
8 53 ms 47 ms 47 ms 63.130.104.194
9 51 ms 38 ms 47 ms 90.255.251.2
10 47 ms 47 ms 48 ms 216.239.41.149
11 47 ms 47 ms 47 ms 172.253.66.87
12 50 ms 47 ms 47 ms dns.google [8.8.8.8]
Is my setup messed up? Any idea why I cannot get a WAN IP with Huawei 4G Modem in Bridge Mode: ON unless I have previously set DHCP Mode: ON? I believe bridge mode is supposed to work with DHCP off, but I am struggling then to get my WAN IP passed to my ASUS Router from the Huawei 4G Modem.tracert 8.8.8.8
2 52 ms 47 ms 47 ms 10.8.0.1
3 50 ms 44 ms 45 ms 5.226.136.129
4 57 ms 48 ms 47 ms ae2.rt0-thn2.ldn.as25369.net [5.226.136.9]
5 48 ms 53 ms 48 ms google1.lonap.net [5.57.80.136]
6 48 ms 55 ms 58 ms 108.170.246.129
7 51 ms 47 ms 45 ms 142.251.54.29
8 * * 46 ms 63.130.104.194
9 * 48 ms 47 ms dns.google [8.8.8.8]
