snbforumuser1234
Hi
I have received a new modem with router functionality from my ISP. It has WiFi and, according to the ISP, should support UPnP IGD for port forwarding. I have no access to the web interface of the router, since all the configuration is done via the control panel on the ISP's website (which doesn't allow manual port forwarding by specifying ports).
Behind this ISP router I have my own router with asuswrt merlin on it. The setup currently is like this:
ISP Router: WAN port has public IP from ISP, LAN port has 192.168.1.1
Asuswrt merlin router: WAN port is connected to ISP router's LAN port and has the ip 192.168.1.2 on it. LAN ports of the asuswrt router are DHCP'd in 192.168.2.X. subnet on all networks is 255.255.255.0.
I have the OpenVPN function enabled in the asuswrt merlin router. However, since my setup is basically a double nat setup, I cannot connect from the internet to my asuswrt merlin router.
I would probably need to send a upnp request on the WAN port of the asuswrt router to my ISP's router, but this doesn't seem to work. I tried to ssh to the asuswrt merlin router and issued "miniupnpc -l", but it doesn't find the ISP router.
What would I need to do?
