double VPN - need help
Russell Bantin
I am new to VPN setups. I am helping a friend setup a remote server for his 2 businesses. They both use the same software and need to connect to the same server via VPN. He has 3 ASUS RT-AC86U routers with openVPN integrated. One would serve and the other 2 are clients. I can get one to connect but not both...
Are they running stock or RMerlin firmware? Are these at three different locations? Are different ports used in the configuration for the second client router?
I have successfully connected multiple client devices to one Asus VPN server. I have connected one Asus router as a client and other client devices, but not two Asus router clients. That said, it should work.
I trust you created two different login IDs on the VPN Server side and assigned one to each client 86u. Also, do both client 86u's connect when tried one at a time?
Sent from my Pixel using Tapatalk
