Doubt on routing table.??
gabox
Hi, I am newbie on world Asus router. I have a rt68u so im very satisfied with it. My doubt is following about routing table. I used my Asus router behind a isp modem bridge. I am a little confusing about 192.168.1.1 i dont know about it ?? and i dont understand on terminology routing table. Thanks a lot for your time.
Lan=192.168.2.0
Wan=179.41.x.x
GUI:
Destination Gateway Genmask Flags Metric Ref Use Type Iface
179.41.x.x * 255.255.255.255 UH 0 0 0 WAN0 ppp0
192.168.2.0 * 255.255.255.0 U 0 0 0 LAN br0
192.168.1.0 * 255.255.255.0 U 0 0 0 MAN0 eth0
default 179.41.x.x 0.0.0.0 UG 0 0 0 WAN0 ppp0
default 192.168.1.1 0.0.0.0 UG 1 0 0 MAN0 eth0
Console output:
gabox@(none):/tmp/home/root# ip route
179.41.x.x dev ppp0 proto kernel scope link
192.168.2.0/24 dev br0 proto kernel scope link src 192.168.2.1
192.168.1.0/24 dev eth0 proto kernel scope link src 192.168.1.33
127.0.0.0/8 dev lo scope link
default via 179.41.x.x dev ppp0
default via 192.168.1.1 dev eth0 metric 1
Your ISP modem probably runs a DHCP server, so the router obtains a lease from that, in addition to the ppp session that routes your Internet access.
thanks @RMerlin is it regular this action ?? could it bring me any trouble on my network?
It's not ideal, you'd normally want to disable the DHCP server on your modem, but otherwise it shouldn't cause any issue since your LAN uses 192.168.2.xxx.
Thanks a lot. I did scanned of 192.168.1.33 (Aicloud ??strange??) and 192.168.1.1 (isp modem adsl) I am going to take your tips my friends so i dont understand why Aicloud does install it there ?
map scan report for 192.168.1.33
Host is up (0.016s latency).
Not shown: 537 closed ports, 458 filtered ports
PORT STATE SERVICE VERSION
22/tcp open ssh Dropbear sshd 0.52 (protocol 2.0)
443/tcp open ssl/http lighttpd 1.4.29
http-title: AiCloud
8443/tcp open ssl/https-alt?
9100/tcp open jetdirect?
9998/tcp open tcpwrapped
ISP Modem:
Starting Nmap 6.40 ( http://nmap.org ) at 2016-06-13 23:47 ART
NSE: Loaded 110 scripts for scanning.
NSE: Script Pre-scanning.
Initiating Parallel DNS resolution of 1 host. at 23:47
Completed Parallel DNS resolution of 1 host. at 23:47, 0.20s elapsed
Initiating SYN Stealth Scan at 23:47
Scanning 192.168.1.1 [1000 ports]
Discovered open port 21/tcp on 192.168.1.1
Discovered open port 80/tcp on 192.168.1.1
Discovered open port 23/tcp on 192.168.1.1
After disable DHCP on isp modem: a strange situation, i can access my Asus router from 192.168.1.33
gabox@lin ~ $ ssh 192.168.1.33
The authenticity of host '192.168.1.33 (192.168.1.33)' can't be established.
RSA key fingerprint is 20:c7:bf:2a:65:ca:0b:d7:9a:cc:d6:7a:39:71:c1:6c.
Are you sure you want to continue connecting (yes/no)? yes
Warning: Permanently added '192.168.1.33' (RSA) to the list of known hosts.
gabox@192.168.1.33's password:
ASUSWRT RT-AC68U_3.0.0.4 Thu Jan 14 03:40:19 UTC 2016
