Download Master Issue Fix
gjf
There is an issue with Download Master: it cannot clean finished task. Possibly it is caused by "stop seeding after finishing download", may be not - but it exists in my router since first use.
The only way to clean the tasks is manually delete everything in the following folder:
\\ROUTER\Download2\config\resume
\\ROUTER\Download2\config\torrents
My question: is it possible to either include a button in some settings of Merlin firmware or create a script that test is the task still downloading - and if not - deletes corresponding files in the above mentioned folders?
