OnlineInAustria
I've recently bought a Draytek 2925 router and am in the process of setting it up. In the firewall section of the control panel, I don't see any of the usual options as far as security. In my old router, there is the option to select from "Low Security" "Typical Security" "High Security" "Lockdown". Most other routers I've had over the years have had similar options.
On the Draytek 2925, in the control panel under the heading "Firewall" there are two options related to filtering inbound and outbound traffic; both options are checked (active). Further down the page there are three checkbox options:
- Always pass inbound fragmented large packets (required for certain games and streaming)
- Enable Strict Security Firewall
- Block connections initiated from WAN
I've found no concrete information on the Draytek website about the policies of the "Strict Security Firewall", and so am concerned about exactly where I stand with this router.
Do I have to configure a bunch of security rules manually?
Is the router basically going to let any and everything through unless I tell it not to?
