Dropbear around 50% CPU normal?
LukeH
On my AC56U with merlin 378.65_2 I just noticed this:
  PID  PPID USER     STAT   VSZ %VSZ CPU %CPU COMMAND
18232 29338 admin    R     1172  0.4   0 49.2 dropbear -p [XXX] -s -j -k
Where [XXX] is the port I use as SSH service port. Is it normal that %CPU as it never seem to go under 45?
Is this while you are logged in? If so, maybe.
The application you are using to view the CPU usage, over what time-span is the average CPU usage calculated? The larger the time-span the more I would be concerned, and vice versa.
Well, using top I was connected.
Attached is a picture from the administration GUI (I don't know how I could see CPU% other then logged in).
Around the red line (on pic) I killed the ssh client and it doesn't seem to improve.
But also while I was connected top didn't reflect the close to 100% (edit: 110-115 actually) usage summed on both cores as the web GUI seem to show.
I'm running OwnCloud and Transmission via chrouted debian.
EDIT:
Using 2 SSH session won't make top show higher value and from debian top shows
  PID USER      PR  NI    VIRT    RES    SHR S  %CPU %MEM     TIME+ COMMAND
18232 root      20   0    1172    208    168 R  98.0  0.1 494:35.89 dropbear
Forget about "%CPU" (which is the average CPU usage during top's configured refresh interval) and configure top to display "TIME" or "TIME+", which displays the total CPU time since the task began, which is the most likely the measurement you want.
http://man7.org/linux/man-pages/man1/top.1.html
Personally I would install "htop" (via entware), rather than use "top".
Disregarding these measurements, are you having any noticeable network problems?
