Corinex AV200 Powerline
http://hantzundpartner.com/corinex/pdf/AV200_Wall_Mount_F.pdf
https://www.tomsguide.com/us/corinex-av200-powerline-and-cablelan,review-667-11.html
TP-Link AV1200 TL-PA8010P KIT V1
https://static.tp-link.com/resources/document/TL-PA8010P_KIT_V1_Datasheet.pdf
So I've previously been using the Corinex. And I've recently come across a good deal on a used TP-Link, so I took it and will be testing when I get back home.
However I wanted to understand, as I haven't been able to find anything that effectively compares DS2 and HomePlug AV2.
The Corinex for example has never been able to connect across different phases. This thread seems to suggest the TP-Link should have no problems doing it https://www.snbforums.com/threads/powerline-ethernet-issues-cross-phases.4178/
In addition I believe the line might have a lot of noise as the corinex even in the same phase was not able to be very far apart.
So the bottom line is; can I expect better connection stability and range with a HomePlug AV2 vs my old DS2?
What are the diferences that allow that?
PS: As I said the deal was too good, so I took it and will be testing. I'm just trying to get a feel of what I can expect.
