DSL-AX82U HTTP/HTTPS Port Forwarding
AX82U-user-2k
Hi all,
I have troubles opening port 80/443 on my DSL-AX82U and forward it to a server running on a local machine and I wondered if the router might be blocking this port internally?
I've confirmed with my ISP that these ports are open and that CGNAT has been disabled on my service. I can forward almost any port - with the exception of 25. However, I can't seem to be able to forward port 80/443.
Any idea what I am missing?
port forwarding enabled:
Local access ports changed to HTTPS only:
I'm running gnuton Asus Merlin version: 3004.388.7_1-gnuton1 at the moment because I thought maybe this firmware has more power than the stock - it wasn't working with the stock firmware neither.
Thank you,
cheers
Phil
If you have access to SSH, you can issue the following command to see what if anything is already listening on those ports that may be preventing you from using them yourself.
netstat -tupln
I realize that some ASUS GUIs have a similar feature (Network Tools->Netstat), but I prefer the command line because it offers more options and more informative display.
Thank you for your answer. Yes, I do have ssh access to the router:
It doesn't look like there is anything listening on port 80 though
Bash:
netstat -tupln | grep 80
tcp        0      0 0.0.0.0:18017           0.0.0.0:*               LISTEN      1566/wanduck
udp        0      0 0.0.0.0:18018           0.0.0.0:*                           1566/wanduck
udp        0      0 127.0.0.1:38000         0.0.0.0:*                           1592/eapd
udp        0      0 127.0.0.1:58000         0.0.0.0:*                           1592/eapd
or 443
[CODE=bash]netstat -tupln | grep 443
tcp        0      0 127.0.0.1:8443          0.0.0.0:*               LISTEN      1704/httpds
tcp        0      0 192.168.50.1:8443       0.0.0.0:*               LISTEN      1704/httpds
One possibility that many ppl overlook is the target machine perhaps having a personal firewall that's preventing the remote access. IOW, the traffic is reaching the target but it's being rejected by the target itself.
If problems persist, I suggest dumping the relevant portions of the firewall so we can see if the port forwarding rules are there, in order, and whether any packets are even reaching the router.
iptables -t nat -vnL
iptables -vnL
Good point. Unfortunately I don't think it's on the target machine.
This is a clean rasbpian setup with nothing running other than a micro python3 server. I can open other ports, e.g. I can do something like this:
sudo python3 -m http.server 21
and open this port on the router.
It's literally just port 80 and 443 which I weirdly can't forward.
sudo iptables -t nat -vnL
Chain PREROUTING (policy ACCEPT 0 packets, 0 bytes)
 pkts bytes target     prot opt in     out     source               destination
Chain INPUT (policy ACCEPT 0 packets, 0 bytes)
Chain OUTPUT (policy ACCEPT 0 packets, 0 bytes)
Chain POSTROUTING (policy ACCEPT 0 packets, 0 bytes)
Bash:
sudo iptables -vnL
Chain ufw-user-input (1 references)
    3   180 ACCEPT     6    --  *      *       0.0.0.0/0            0.0.0.0/0            tcp dpt:80
    0     0 ACCEPT     17   --  *      *       0.0.0.0/0            0.0.0.0/0            udp dpt:80
    0     0 ACCEPT     6    --  *      *       0.0.0.0/0            0.0.0.0/0            tcp dpt:443
    0     0 ACCEPT     17   --  *      *       0.0.0.0/0            0.0.0.0/0            udp dpt:443
    0     0 ACCEPT     6    --  *      *       0.0.0.0/0            0.0.0.0/0            tcp dpt:22
    0     0 ACCEPT     17   --  *      *       0.0.0.0/0            0.0.0.0/0            udp dpt:22
    1    60 ACCEPT     6    --  *      *       0.0.0.0/0            0.0.0.0/0            tcp dpt:21
    0     0 ACCEPT     17   --  *      *       0.0.0.0/0            0.0.0.0/0            udp dpt:21
    1    60 ACCEPT     6    --  *      *       0.0.0.0/0            0.0.0.0/0            tcp dpt:8080
    0     0 ACCEPT     17   --  *      *       0.0.0.0/0            0.0.0.0/0            udp dpt:8080
and ufw
Bash:
sudo ufw status
Status: active
To                         Action      From
80                         ALLOW       Anywhere
443                        ALLOW       Anywhere
22                         ALLOW       Anywhere
21                         ALLOW       Anywhere
8080                       ALLOW       Anywhere
80 (v6)                    ALLOW       Anywhere (v6)
443 (v6)                   ALLOW       Anywhere (v6)
22 (v6)                    ALLOW       Anywhere (v6)
21 (v6)                    ALLOW       Anywhere (v6)
8080 (v6)                  ALLOW       Anywhere (v6)
Sorry, did you mean `iptables -t nat -vnL` on the router right? The above is from the target machine 🙈
Update: iptables from the router:
Chain PREROUTING (policy ACCEPT 1554 packets, 181K bytes)
  153 14310 GAME_VSERVER  all  --  *      *       0.0.0.0/0            x.hidden.hidden.x
  152 14266 VSERVER    all  --  *      *       0.0.0.0/0            x.hidden.hidden.x
Chain INPUT (policy ACCEPT 675 packets, 73773 bytes)
Chain OUTPUT (policy ACCEPT 335 packets, 29548 bytes)
Chain POSTROUTING (policy ACCEPT 328 packets, 28385 bytes)
 1144  126K PUPNP      all  --  *      wan0    0.0.0.0/0            0.0.0.0/0
  879  107K MASQUERADE  all  --  *      wan0   !x.hidden.x        0.0.0.0/0
    9  1267 MASQUERADE  all  --  *      br0     192.168.50.0/24      192.168.50.0/24
Chain DNSFILTER (0 references)
Chain GAME_VSERVER (1 references)
    0     0 DNAT       tcp  --  *      *       0.0.0.0/0            0.0.0.0/0            tcp dpt:2222 to:192.168.50.69:2222
    1    44 DNAT       tcp  --  *      *       0.0.0.0/0            0.0.0.0/0            tcp dpt:80 to:192.168.50.69:2222
    0     0 DNAT       tcp  --  *      *       0.0.0.0/0            0.0.0.0/0            tcp dpt:443 to:192.168.50.69:2222
Chain LOCALSRV (0 references)
Chain MAPE (0 references)
Chain PCREDIRECT (0 references)
Chain PUPNP (1 references)
Chain VSERVER (1 references)
    0     0 DNAT       tcp  --  *      *       0.0.0.0/0            0.0.0.0/0            tcp dpt:80 to:192.168.50.64
    0     0 DNAT       tcp  --  *      *       0.0.0.0/0            0.0.0.0/0            tcp dpt:443 to:192.168.50.64
    1    60 DNAT       tcp  --  *      *       0.0.0.0/0            0.0.0.0/0            tcp dpt:21 to:192.168.50.64
  151 14206 VUPNP      all  --  *      *       0.0.0.0/0            0.0.0.0/0
Chain VUPNP (1 references)
With `iptables -vnL`, are you looking for something specific, it's pretty big.
Aah, I found it, thank you for the hint.
I weirdly enough had some `GAME_VSERVER` section in there, which is a special config in the webinterface. I've removed the invalid port forwardings and now it's working 🙈
Thank you.
