Dual instances of Minidlna possible?
Hexabion
I did some digging (googling), which I often do when I get "crazy" ideas, and lo and behold, I found examples and descriptions on how to run multiple instances of minidlna, so I tried it - to no success.
When doing "minidlna -?", it says you can use a -u parameter to give the instance its own UUID, so i tried that, starting two different minidlna's with two different conf's, two different db-dirs and mediadirs and friendly-names etc, and then tried to start them both with each their -u setting i commandline. basically something like this:
/opt/bin/minidlna -u 898989 -h -f /opt/var/minidlna-a.conf
/opt/bin/minidlna -u 676767 -h -f /opt/var/minidlna-b.conf
All that happends is that first one gets started, but second one, nothing. The second instance gives no error-output in the shell, it creates an empty logfile in its db-dir, but doesnt stick in memory / just finishes like nothing ever happened.
Have anyone tried this? Am I chasing down a mythical bird here that doesn't actually exist? (meaning, its been included in the help/manual, but not actually been implemented yet - at least not for the entware compilation).
Shared experiences would be much appreciated, and thanks in advance.
you cannot load minidlna multiple times; that was the issue I had. I also had the problem of playing FLAC files from my Asus RT-AC87U, so that my Roberts Radio would work with any audio format: I needed to transcode the files. I therefore had to compile from source ReadyMedia (an offshoot of minidlna) to use its transcoding features. I also modified the source code and added the -M option, so I could create multiple instances of ReadyMedia e.g
Usage:
ReadyMedia2 [-d] [-v] [-f config_file] [-p port]
[-i network_interface] [-u uid_to_run_as]
[-t notify_interval] [-P pid_filename]
[-s serial] [-m model_number]
[-w url] [-M MACaddress] [-R] [-L] [-S] [-V] [-h]
I ended up - after a couple of weeks - in getting the executable ReadyMedia2 working on both my RT-AC68U and my RT-AC87U successfully. Another issue is loading LIBSQLITE3 i.e not a static library. A LDD dump of ReadyMedia2 shows it successfully loads from a different directory, as do some of the other libraries:
admin@RT-AC87U-F390:/tmp/mnt/SAMSUNG/minidlna# ldd ReadyMedia2
libexif.so.12 => /usr/lib/libexif.so.12 (0x401de000)
libvorbis.so.0 => /usr/local/lib/libvorbis.so.0 (0x40119000)
libid3tag.so.0 => /usr/local/lib/libid3tag.so.0 (0x40149000)
libjpeg.so => /usr/lib/libjpeg.so (0x40163000)
libogg.so.0 => /usr/local/lib/libogg.so.0 (0x40185000)
libFLAC.so.8 => /usr/local/lib/libFLAC.so.8 (0x40214000)
libpostproc.so.53 => /usr/local/lib/libpostproc.so.53 (0x40191000)
libswresample.so.1 => /usr/local/lib/libswresample.so.1 (0x400e7000)
libavutil.so.54 => /usr/local/lib/libavutil.so.54 (0x40262000)
libavformat.so.56 => /usr/local/lib/libavformat.so.56 (0x402c9000)
libavcodec.so.56 => /usr/local/lib/libavcodec.so.56 (0x4033e000)
libsqlite3.so.0 => /usr/local/lib/libsqlite3.so.0 (0x406ef000)
libfdk-aac.so.0 => /usr/local/lib/libfdk-aac.so.0 (0x40795000)
libMagickCore-6.Q16.so.2 => /usr/local/lib/libMagickCore-6.Q16.so.2 (0x4081f000)
libMagickWand-6.Q16.so.2 => /usr/local/lib/libMagickWand-6.Q16.so.2 (0x40b58000)
libpthread.so.0 => /lib/libpthread.so.0 (0x401a7000)
libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x40103000)
libc.so.0 => /lib/libc.so.0 (0x40c56000)
libm.so.0 => /lib/libm.so.0 (0x401c1000)
libogg.so.0 => /usr/lib/libogg.so.0 (0x40cca000)
libz.so.1 => /usr/lib/libz.so.1 (0x400c5000)
ld-uClibc.so.0 => /lib/ld-uClibc.so.0 (0x4006b000)
I also had to slim down FFMPEG, so that it didn't run out of memory. Here is a PS dump of ReadyMedia2 processes running on my system using the -M option:
1985 admin 13072 S /usr/local/bin/ReadyMedia2 -M OST -P /mnt/SAMSUNG/minidlna/OST.pid -f /mnt/SAMSUNG/minidlna/OST.conf
1986 admin 13072 S /usr/local/bin/ReadyMedia2 -M OST -P /mnt/SAMSUNG/minidlna/OST.pid -f /mnt/SAMSUNG/minidlna/OST.conf
1987 admin 13072 S N /usr/local/bin/ReadyMedia2 -M OST -P /mnt/SAMSUNG/minidlna/OST.pid -f /mnt/SAMSUNG/minidlna/OST.conf
2008 admin 13680 S /usr/local/bin/ReadyMedia2 -M MYSONGS -P /mnt/SAMSUNG/minidlna/MYSONGS.pid -f /mnt/SAMSUNG/minidlna/MYSON
2010 admin 13680 S /usr/local/bin/ReadyMedia2 -M MYSONGS -P /mnt/SAMSUNG/minidlna/MYSONGS.pid -f /mnt/SAMSUNG/minidlna/MYSON
2011 admin 13680 S N /usr/local/bin/ReadyMedia2 -M MYSONGS -P /mnt/SAMSUNG/minidlna/MYSONGS.pid -f /mnt/SAMSUNG/minidlna/MYSON
2028 admin 13472 S /usr/local/bin/ReadyMedia2 -M MYSONGS2 -P /mnt/SAMSUNG/minidlna/MYSONGS2.pid -f /mnt/SAMSUNG/minidlna/MYS
2030 admin 13472 S /usr/local/bin/ReadyMedia2 -M MYSONGS2 -P /mnt/SAMSUNG/minidlna/MYSONGS2.pid -f /mnt/SAMSUNG/minidlna/MYS
2031 admin 13472 S N /usr/local/bin/ReadyMedia2 -M MYSONGS2 -P /mnt/SAMSUNG/minidlna/MYSONGS2.pid -f /mnt/SAMSUNG/minidlna/MYS
2049 admin 13612 S /usr/local/bin/ReadyMedia2 -M DISCOGS -P /mnt/SAMSUNG/minidlna/DISCOGS.pid -f /mnt/SAMSUNG/minidlna/DISCO
2051 admin 13612 S /usr/local/bin/ReadyMedia2 -M DISCOGS -P /mnt/SAMSUNG/minidlna/DISCOGS.pid -f /mnt/SAMSUNG/minidlna/DISCO
2052 admin 13612 S N /usr/local/bin/ReadyMedia2 -M DISCOGS -P /mnt/SAMSUNG/minidlna/DISCOGS.pid -f /mnt/SAMSUNG/minidlna/DISCOGS
Therefore, OST, MYSONGS, MYSONG2 and DISCOGS are all separate SQLite3 databases with their own PID's.
Regards
After Note:
It should be noted that -M MACaddress option in ReadyMedia2 can be a literal string e.g. MYSONGS (a maximum of 12 characters), as the name is converted internally to a MAC address.
Thanks for the info nairn, maybe you could post/upload your compilation.
I suspect your solution won't work on a N66U though, since the version you have of ReadyMedia(2) is most likely for arm-cpu's, but for all those with arm (most, if not all ACXXXX routers) this would be very usefull.
