TramVanCollision
Hi everyone,
A long-time lurker, first time poster here; thanks for everyone's past contributions to these forums, they've been invaluable to me over the years!
I recently decided to complicate my home network a little by adding a second router into the mix.
I'm doing this primarily because the additional router supports a proprietary VPN service to link to a telematics network but also because it should enable me to use a cellular connection as a backup WAN.
These forums contain various threads that refer to setups that use dual routers, double NAT & dual WAN and I've tried to follow the advice within them but I can't get it to work, my head is now hurting and I realise that I need some help!
I've attached a diagram that shows the dual router network design that I arrived at.
I have tested the WAN connectivity on Router A via a direct LAN Ethernet connection (192.168.50.0/24) and all is well but clients connected to the LAN behind Router B (192.168.1.0/24) can't access Router A or the Internet beyond it.
Please could one of your very lovely and helpful people suggest where I might be going wrong?
As you can see from the diagram, once (if) I get the underlying networking working I's then like routes from the LAN (192.168.1.0/24) to an IPSec VPN client on Router B and the Peplink VPN service on Router A.
