T.S.Fellow
Does this setup actually help? I'm running one gig fiber line into modem. Then two Lan lines into an rt-ac88u one Wan and the other Lan as the dedicated dual wan port.
I did some custom routing and other testing, things seem quicker, but I'm not sure if there's any actual real world load balancing happening setting it up this way. Or do I legit need two ISP's, or at least two separate fiber lines incoming to make a difference? Thanks.
