Dual WAN and Port Forwarding
HRearden
I tried out the Dual WAN feature the other day using an Android phone on USB as Secondary. I have several port forwards which seemed to quit working as long as Dual WAN was enabled (secondary connection was not necessary). The port forwards would not work while using Primary WAN until I disabled Dual WAN and then they immediately started working again.
Has anyone else seen that behaviour?
I am using 380.68 on AC68U
rearden
rearden
Most likely your Android's 3G/4G mobile provider implements CGNAT, which blocks any kind of port forwarding
EDIT: just noticed you've said it was merely enabling Dual WAN, rather than using the secondary connection, so my point is likely irrelevant!
