Dual WAN + Dual Firewall
Zim
Thinking about adding a pf/opnsense firewall/router as VM in Proxmox. I'm concerned that during updates or for any other reason the VM/firewall/router is down, the network will be down.
Is it possible for me to enable dual WAN on the Asus router so that when WAN1 is up the Asus router firewall is off because the traffic is routed through pf/opnsense firewall/router. When WAN1 goes down and WAN2 comes online, the Asus firewall turns on.
It sounds simple, but not able to find anything online about it.
No separate per interface firewall options in Asuswrt GUI. Run pfSense on a dedicated hardware with UPS backup. Virtualized firewall running on a 10-in-1 appliance is not the best option. All your network services will be dependent on single device. What’s the difference in reliability compared to home All-in-One router?
There is a script fixing buggy Dual WAN in Asuswrt. 😬
It wouldn't do what he is asking though, what you could do is add commands to start/stop the firewall to the wan-event script accordingly for WAN0 or WAN1 being connected or disconnected.
Here you go, two birds with one stone. 👍
Sounds like what I am looking for, thanks @Ranger802004.
How would I go about setting this up?
Would I create a WAN-event file under /jffs/scripts/ and use the code below?
#!/bin/sh
case "$1" in
    wan0_down)
        # Commands to execute when primary WAN goes down
        service firewall start
    wan0_up)
        # Commands to execute when primary WAN goes online
        service firewall stop
esac
#!/bin/sh
case "$1" in
    wan0_down)
    wan0_up)
esac
For your case I'd do a case statement or if statement based on which WAN is primary WAN.
I'm not sure how to do that. The previous version was what ChatGPT spit out lol.
If it's not too much trouble, could I ask you to do one for me please.
Not sure why is this complication needed. If the clients are connected to the Asus router the pfSense firewall upstream will see single client only (the Asus) with mostly encrypted hard to identify traffic. There is no point of this pfSense firewall in this case since you can't use any of the advanced features on it.
