xaviercharles
Hey guys,
Firmware:- 374.43_2-04j9527 FORK
I have two cable modem connections in my home one @152/12 and the other @50/3. With the hope of combining both connections so i get 202/15.
I've enabled dual wan set primary wan as WAN and secondary wan as ethernet Lan @ Lan port 1. Set dual wan mode to Load Balancing and set the load balancing ratio @ 3:1.
First issue i ran into was the secondary wan port was not getting an IP address. So i thought it could be a mac address issue with the LAN port. So i manually assigned a MAC address to it by going to the WAN->Internet Connection page, selected wan type ethernet lan. Which solved that problem.
Under the Network Map section it says Primary WAN connected and Secondary WAN connected both with different WAN ip's and different gateway addresses.
Here comes the final problem if i set the load balance ratio to 3:1 i cant get over 152/12 when i set it to 1:1 i cant get faster than 50/3.
If anyone knows what i have to do so get a total throughput of 202/15 and could tell me i'd really appreciate it.
