stylish_me
Started using dual wan setting with usb modem as secondary wan. And noticed a huge bug.
There are no ip, dns, gateway etc. settings for secondary wan when you use usb modem.
This means that when you use usb modem as secondary wan - it tries to get the same ip, tries to use same dns and so on - using your isp settings from primary wan settings page (my isp gives fixed ip, dns, etc settings). Sure secondary wan gets lots of errors because cellular 3g modem wan should get absolutely different ip, use it's own gateway, dns and so on.
@RMerlin Any chance to fix it? Current settings cause serious problems..
