From what I know the dual WAN feature is if you have 2 different ISP modems and you want to merge them together to achieve faster speeds by utilizing both services at once. You can then setup a VPN but it will go via both modems. So what you are asking for is not possible.I want to configure dual WAN with one WAN having a VPN to another site. Internet use will be using WAN1 and inner office traffic WAN2. Is this possible and are there any posts of documents that can help?
I have 2 Asus RT-N66U routers at both locations.I am not sure how to achieve this, I don't have two Internet connections to test DUAL WAN
you will have to use DUAL WAN with Load Balancing, because DUAL WAN in Fail-over mode isn't able to deliver what you are asking for
maybe with some iptables scripts (magic) you could get this done eventually
do you have two Internet connections to test this? which Asus router do you have?
Welcome To SNBForums
