Has anyone had the following happen:
Using an iPad (doesn't matter which version, 3, Air, etc) on the 5Ghz band, will work fine for a few hours, but after awhile I seem to trigger a bug in which everything slows to a crawl on the wireless device.
I ran speed test and it timed out like there was no connection. After 5-10 minutes it may load a page but its VERY slow. After rebooting the iPad everything is fine (but I noted, before, this occurs on > 1 device).
The CTF is disabled.
The 5Ghz Settings:
Wireless-N Only
SSID: XXXX
Channel Width: Auto (20 MHz or 40 MHz)
Channel: Auto (DFS)
I have tried manually selecting the channel as well the problem still occurs. Next time I will reboot (power cycle the router) to see if that solves the issue as well. I see various reports on forums of similar behavior but wanted to see if someone could confirm this issue.
The 5Ghz Settings:
Wireless-N Only
SSID: XXXX
Channel: Auto (DFS)
