Edgemax Lite 3 IP Change Question
leonsmalto
Hi Guys ,
I'm looking for help to setup edgemax lite3 with two different IP address .
I did follow the setup above :http://wiki.ubnt.com/SOHO_Edgemax_Example
excellent write up ,got me online under 20 minutes excellent.
But my problem is that my home automation equipments are setup to use IP sequence of 10.0.1.1 from Airport Extreme .
how can I go to set up my EDGEMAX with 10.0.1.1 so I can remove AE in the mix .
I would like to have if possible:
eth1:192.168.1.1
eth2:10.0.1.1
Is this possible ?
Thanks in advance
Hi Guys ,
eth1:192.168.1.1
eth2:10.0.1.1
Is this possible ?
Thanks in advance
Yea, sure. If you follow the wiki you referenced above just put in 192.168.1.1 where the wiki has 172.16.0.1 (for Eth1) and put 10.0.1.1 where the WIKI has 172.16.1.1.
After that change your DNS servers to reflect your changes (reference the wiki again). The router will build the routing table for you and you should be good to go. I use an Edgerouter Lite and have been very happy with it.
