RussellInCincinnati
With a 10-meters-away RT-AC68u (3-stream 802.11ac) router running 384.4 Merlin firmware, my Edimax 7833uac USB WiFi network adapter ($35 dollars or so) connects at 1.3 gigabits per second nominal link rate on a 5 gigahertz channel. Connection strength on Linux reads "100%." The older Edimax 7822uac adapter, same computer, links at 867Mbps (which it should) with connection strength "70%." This is with completely up-to-date Manjaro / Arch Linux kernel 4.14. The newer 7833uac is a 3-stream 802.11ac wifi adapter, the 7822 is a two-stream adapter.
Under Windows 10 the older '7822 connects occasionally, sometimes, after multiple tries. The 7833uac works great immediately.
Guess this could be that my 7822 adapter is now defective, but the Windows problems with it coincidentally did not appear with older Merlin/Asus firmware.
Moral of the story is if you have a 7822uac and are talking to a Merlin '68u router, give it to a friend and get the 7833uac.
