Editing nvram variables
johnathonm
I was wondering about editing nvram variables. I know it's possible to do with entware and busybox. If we were going to make changes where would they be placed? Or is that not possible at this time?
Thanks,
J
:confused::confused::confused: NVRAM variables are stored in... NVRAM. You can manipulate them with the "nvram" command, that's nothing to do with entware or busybox.
Sorry, I meant the sysctl -a variables.
I know I would use cat /sys/proc, but is there a list of these values that would correspond to what you'd get with sysctl. There is sysctl as part of busybox entware, btw.
I think the names are fairly self-evident. What exactly are you looking for?
Yes I know, but it's not included in the basic firmware.
I want to tweak some of the defaults a bit. I am ok/good with unix. I just am not as used to doing it the longer way with cat.
I just want to experiment really, it's an academic exercise to learn and to possibly tweak out a bit more performance.
I have been looking at the vm and wmem etc, settings and want to adjust them. Maybe more.
I can't think of an easy way of displaying the value of every attribute in one go without installing additional software.
The best I can come up with is something like this:
# find /proc/sys
# find /proc/sys | grep wmem
/proc/sys/vm/lowmem_reserve_ratio
/proc/sys/net/core/wmem_max
/proc/sys/net/core/wmem_default
/proc/sys/net/ipv4/tcp_wmem
/proc/sys/net/ipv4/udp_wmem_min
# cat /proc/sys/net/core/wmem_max
122880
how can we make changes persistent
sysctl config is not used
never mind
included
echo 2500000 > /proc/sys/net/core/rmem_default
with a startup script i made earlier adding that line
You would have to put the commands in a user script. Which particular user script would depend on what it was you're changing, but often that's init-start.
Yeh i figured i already made such a script
my script now
Which router and why did you likely reduce them by 1/2?
When creating scripts anything you can read with cat you can read/write with nano or vi as long as you have the permissions.
When creating a new script just make sure to give it executable permissions.
chmod a+rx /jffs/scripts/*
This is incorrect. Only regular files can be edited with the likes of vi or nano. Virtual files in /proc cannot be edited even though they can be read or written to.
Your correct. I didn’t mean /proc, so not everything even if they technically can be written to; anything that’s automatically changed by the system shouldn’t be changed directly as it will be overwritten.
