Emulate port mirror on RT-N66U to verify traffic encryption
chichow
SNBForum / Merlin
HELP: Need to mirror WAN traffic going to local LAN port (Synology connected to RT-N66U) to another local LAN port (Mac running Wireshark).
I think I can do this with iptables. Can someone help with the iptables command?
Synology is at 192.168.1.100
Mac running wireshark is at 192.168.1.200
Asus is at 192.168.1.1
The command I see on the internet is
iptables -t mangle -A POSTROUTING -d 192.168.1.100 -j ROUTE --tee --gw 192.168.1.200
iptables -t mangle -A PREROUTING -s 192.168.1.100 -j ROUTE --tee --gw 192.168.1.200
but I don’t see “—tee or —gw” listed in the help section for iptables v1.3.8
WHY: I have a Synology on my local LAN. It is backing up to another Synology at a remote site. I’d like to verify that the traffic is encrypted.
MORE DETAILS: Running iptables v1.3.8
ASUSWRT-Merlin RT-N66U_3.0.0.4 Sun Mar 20 19:51:30 UTC 2016
admin@RT-N66U-9790:/tmp/home/root# iptables -h
iptables v1.3.8
Usage: iptables -[AD] chain rule-specification [options]
iptables -[RI] chain rulenum rule-specification [options]
iptables -D chain rulenum [options]
iptables -[LFZ] [chain] [options]
iptables -[NX] chain
iptables -E old-chain-name new-chain-name
iptables -P chain target [options]
iptables -h (print this help information)
Commands:
Either long or short options are allowed.
--append -A chain Append to chain
--delete -D chain Delete matching rule from chain
--delete -D chain rulenum
Delete rule rulenum (1 = first) from chain
--insert -I chain [rulenum]
Insert in chain as rulenum (default 1=first)
--replace -R chain rulenum
Replace rule rulenum (1 = first) in chain
--list -L [chain] List the rules in a chain or all chains
--flush -F [chain] Delete all rules in chain or all chains
--zero -Z [chain] Zero counters in chain or all chains
--new -N chain Create a new user-defined chain
--delete-chain
-X [chain] Delete a user-defined chain
--policy -P chain target
Change policy on chain to target
--rename-chain
-E old-chain new-chain
Change chain name, (moving any references)
Options:
--proto -p [!] proto protocol: by number or name, eg. `tcp'
--source -s [!] address[/mask]
source specification
--destination -d [!] address[/mask]
destination specification
--in-interface -i [!] input name[+]
network interface name ([+] for wildcard)
--jump -j target
target for rule (may load target extension)
--goto -g chain
jump to chain with no return
--match -m match
extended match (may load extension)
--numeric -n numeric output of addresses and ports
--out-interface -o [!] output name[+]
--table -t table table to manipulate (default: `filter')
--verbose -v verbose mode
--line-numbers print line numbers when listing
--exact -x expand numbers (display exact values)
[!] --fragment -f match second or further fragments only
--modprobe=<command> try to insert modules using this command
--set-counters PKTS BYTES set the counter during insert/append
[!] --version -V print package version.
Just because that command isn't explicitly mentioned in the help doesn't necessarily mean that it's not available.
Have you actually tried using it? I've just tried it on my N66U and it works as expected.
