Enable Guest network disable all wireless
Jeff Rinvelt
My on 384.5 with a RT-AC88 and decided to play with guest networks. It seems every time I enable a guest network it turns off all wifi networks (including the guest network). A reboot of the router gets everything working again but the guest network has to be disabled.
I went back to factory settings and reset all my settings and the issue continues. Any know issues with 384.5 or what am I missing?
I'm not sure, but it sounds to me like you're just applying your settings and not waiting for it to bring the networks back up... like a reboot does.
playing around with guest Wifi wont turn off any Wifi on my routers, so sure he got an issue!
update to 384.6_b1
