Andrew Lieb
I have an RT-AC66U router. With the latest official ASUS FW release, as well as all before it, I can't get OpenVPN server to work with my Mac. I understand the issue to be related to the dhparams.pem key being 512 bits, when OpenSSL on the Mac now requires 2048 bits. Several forum posts elsewhere suggest that you can create a 2048 bit key on Linux or OS X and paste it into the appropriate ASUS router field. However, I was never able to get the router to accept the longer key. After clicking on "Apply", the status of OpenVPN Server was always "problem with the configuration of the Diffie-Hellman key".
To resolve this issue, I upgraded to RT-AC66U_378.55_beta2 Merlin code -- which supposedly uses a "pre-made 2048 bit key" (with some questions about whether this is a good idea to not generate a unique key, but anyway...).
The FW installs fine. However, now when I try to configure OpenVPN server, the router stays forever in the status of "Initializing the settings of OpenVPN server now, please wait a few minutes to let the server to setup completed before VPN clients establish the connection" and the router is running at 100 percent CPU and gets very hot.
Even with a hard reboot, the router remains in this state. The only way to get it back to normal is to disable the OpenVPN server.
Any solutions here?
Any solutions here?
