Enabling STP on RT-AX88U
ciprian.trofin
To enable STP on router - do I have to do something else than go admin interface - Advanced Settings - LAN - Switch Control - Spanning-Tree Protocol - ENABLE ?
I'm asking because if I SSH the router and enter
brctl show
I get
bridge name     bridge id               STP enabled     interfaces
br0             8000.3c7c3fdc4558       no              eth1
                                                        eth2
                                                        eth3
                                                        eth4
                                                        eth5
                                                        eth6
                                                        eth7
Is STP enabled or not ?
@eibgrad: thank you.
I did as you instructed me and I think it works - Wireshark running on a laptop (wirelessly connected to network) shows STP packets when STP is enabled manually (via brctl); the STP packets stop showing when the STP is disabled with
brctl stp br0 off
I don't know if it solves my underlying problem (not discussed here), but hey! at least I can see STP packets flowing :)
However, it also looks like:
1. there are no STP packets flowing when STP is enabled only via Switch Control; bug, maybe?
2. rebooting the router disables STP; is there any way to enable it at boot time?
May very well be a bug. If manually enabling it works, I suppose you could add the command as an init-start script.
I have the same issue with an RT-BE88U. In this case though it gets reset to "no" at some point. I have the command in init-start - could I move this to services-start which gets called several times a day?
Answered this myself. Yes, adding to services-start rather than init-start has STP active constantly (well, as often as I'm checking it right now).
Thank you for sharing. I have enabled STP on the main router and all nodes via commands. If a network loop occurs or if the physical network speed drops from 1G to 100M, I will receive STP topology change messages. Therefore, receiving topology change messages is the first step in identifying network issues. Like this:
Main:
Nodes:
I'm also quite curious, like ciprian.trofin asked, why is the STP result shown by the brctl show command inconsistent with what is displayed on the web UI?
Who knows. I learned early on not to ask myself questions like that for fear of just frustrating myself.
I wonder how long it's been like this, and how many routers are affected. So many peeps unaware - I only investigated when I got a new managed switch, where activating stp slowed routing to a crawl while the cpu was constantly topped out.
AX88U, AC88U, AC86U, AC68U
the question may well be, what ones are not affected.
@RMerlin The merge with GPL 388_24353 on 19/12/2023 added this condition in lan.c which prevents STP being set on br0 for most HND models.
I guess the thinking was that the following hnd_set_hwstp(); would take care of this but that does not seem to be the case as I see no STP traffic on the LAN.
Since hnd_set_hwstp() is closed source, I have no idea what the logic is within that function. I have to trust that Asus did things this way for a reason.
