encfs (arm version, Entware) is ready for testing
I created an encfs directory and copied some files to/from it using NFS. Compared to using NFS without encryption I get around 90-95% of both read and write performance with a USB 3 stick.
Haven't tried SMB, but see no reason why it shouldn't work there as well.
What's a bit strange, is that I can't see any files when I'm logged in through ssh and do an ls. My Testenc directory shows up as being empty and the .testenc directory only contains a .encfs6.xml dotfile. Is this normal?
I don't think this is working at all. After rebooting I wanted to see if it was working, and tried mounting it by using: encfs -v /tmp/mnt/usbstick/.testenc /tmp/mnt/usbstick/Testenc
2017-02-16 13:42:11,407 VER [main.cpp:548] Root directory: /tmp/mnt/usbstick/.testenc/
2017-02-16 13:42:11,407 VER [main.cpp:549] Fuse arguments: (daemon) (threaded) (keyCheck) encfs /tmp/mnt/usbstick/Testenc -o use_ino -o default_permissions
2017-02-16 13:42:11,410 VER [FileUtils.cpp:294] found new serialization format
2017-02-16 13:42:11,410 VER [FileUtils.cpp:308] subVersion = 20100713
2017-02-16 13:42:11,410 VER [Interface.cpp:110] checking if ssl/aes(3:0:2) implements ssl/aes(3:0)
2017-02-16 13:42:11,411 VER [SSL_Cipher.cpp:328] allocated cipher ssl/aes, keySize 16, ivlength 16
2017-02-16 13:42:11,411 VER [FileUtils.cpp:1575] useStdin: 0
EncFS Password: [i]<entered correctly>[/i]
2017-02-16 13:42:13,986 VER [Interface.cpp:110] checking if ssl/aes(3:0:2) implements ssl/aes(3:0)
2017-02-16 13:42:13,986 VER [SSL_Cipher.cpp:328] allocated cipher ssl/aes, keySize 16, ivlength 16
2017-02-16 13:42:14,479 VER [FileUtils.cpp:1583] cipher key size = 36
2017-02-16 13:42:14,480 VER [Interface.cpp:110] checking if nameio/block(4:0:2) implements nameio/block(4:0)
hemreviret@Jupiter:/tmp/mnt/HyperX_32GB# fuse failed.  Common problems:
 - fuse kernel module not installed (modprobe fuse)
 - invalid options -- see usage message
modprobe fuse returns:
modprobe: module fuse not found in modules.dep
But in dmesg I can see it's loaded:
VFS: Disk quotas dquot_6.5.2
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
squashfs: version 4.0 (2009/01/31) Phillip Lougher
fuse init (API version 7.15)
msgmni has been set to 499
Progress update!
My RT-AC87U doesn't seem to have enough free memory for encfs, and after rebooting I forgot to enable the swapfile.
Now it mounts and works properly, but not with NFS. All the other directories within the NFS share are accessable.
I tried chown'ing the directory to have the same as the others("nas" as user/group), 777'ing it and also mounting it with the --public encfs option. No change - trying to access it through NFS says I lack permissions.
What's weird is that I can access the encrypted .testenc directory and read/write content inside it.
I don't know where to go from here, really. Any help would be appreciated. :(
