I want to buy new router maybe two new ones but
don't know which one to get and or if two are even needed. My current
setup consists of belkin-n wireless router that is hooked up to my cable
modem and main pc in the basement this is the one that broke. I also
have linksys WRT54GS v1 on the 2nd floor on my other pc running in
repeater mode using dd-wrt. What should I get EnGenius ERS-9850 or
TP-Link TL-WR1043ND also do I need to replace my WRT54GS to get better
speeds on my 2nd PC. I also want to upgrade the antennas with the
TP-Link 5dbi antenna. Is there any other way to get internet to my
second pc other than having the WRT54GS plugged into the lan port and
into my pc and running in repeater mode. I know my connection speed gets
cut in half with the repeater mode is there anyother options. Would AP
mode work on my 2nd PC, I never tried it. If I can't run anything other
than repeater do you recommend EnGenius ERB9250 with TP-Link 5dbi
antennas if I was going with the EnGenius Brand or just get another
ERS-9850, cause if I'm going with TP-Link I would need another
TL-WR1043ND and just flash it with dd-wrt to get repeater mode on it.
I'm kinda lost and don't know what to do, also if you tell me to keep
the WRT54GS would the TP-Link 5dbi antennas work on it. One more thing I
read your review on the ERS-9850 and I read that you were having
disconnect problems, do you know if the new firmware 2.0.2 sorts this
problem out. Hope you can help me out.
Thanks.
Thanks.
