James Rogers
I am in the US. I have set up an openvpn on my ASUS RT-AC5300 router which I purchased due to its ability to run a VPN. I am lucky enough to have a gigabit connection. I am running a wired connection to my desktop and to my Roku device. With the VPN on the router disabled, I am getting speeds on the desktop of about 945 Mbps down and 650 up. With the VPN on the router connected, I am getting speeds of about 35 up and 40 down on the desktop. Plus, my Ruku device has major difficulty streaming Netflix and Amazon will not stream at all.
For obvious reasons, I wanted to use the VPN on the router, but the reduction in speed and lack of streaming ability are prohibitive. On my AC wireless laptop with the VPN connected, I am getting about 55 down and 108 up. Off, I am getting 220 up and 225 down. So, the VPN on the laptop and desktop is substantially reducing speeds, but not as much as it is being reduced with the VPN on the router. Ideas? Suggestions? Thanks. Using speedtest.net
Also, can anyone suggest a router with enough CPU to handle the openvpn encryption and maintain a descent bandwidth?
