entware.arm not installing on RT-AC68U (378.52_2)
feranick
Hi, I am running 378.52_2 on a RT-AC68U. I am trying to install entware through the entware-setup.sh script, but unsuccessfully (output below). I have a ext3 partition on my external drive that is correctly detected, but I can't seem to get entware to work...
Thanks for any insight.
admin@RT-AC68U:/tmp/home/root# entware-setup.sh
Info:  This script will guide you through the Entware-Arm installation.
Info:  Script modifies only "entware.arm" folder on the chosen drive,
Info:  no other data will be touched. Existing installation will be
Info:  replaced with this one. Also some start scripts will be installed,
Info:  the old ones will be saved on partition where Entware is installed
Info:  like /tmp/mnt/sda1/jffs_scripts_backup.tgz
Info:  Looking for available partitions...
[1] --> /tmp/mnt/sda2
=>  Please enter partition number or 0 to exit
[0-1]:
[: bad number
Info:   selected.
Info:  Creating /entware.arm folder...
mkdir: can't create directory '/entware.arm': Read-only file system
Info:  Creating /tmp/opt symlink...
ln: /tmp/opt: File exists
Info:  Creating /jffs scripts backup...
tar: can't open '/jffs_scripts_backup_2015-04-25_21-59.tgz': Read-only file system
Info:  Modifying start scripts...
Info:  Starting Entware-Arm deployment....
--2015-04-25 21:59:55--  http://qnapware.zyxmon.org/binaries-armv7/installer/entware_install_arm.sh
Resolving qnapware.zyxmon.org... 81.4.123.217
Connecting to qnapware.zyxmon.org|81.4.123.217|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 1711 (1.7K) [text/x-sh]
Saving to: 'entware_install_arm.sh.2'
entware_install_arm.sh.2 100%[====================================>]   1.67K  --.-KB/s   in 0s
2015-04-25 21:59:56 (46.0 MB/s) - 'entware_install_arm.sh.2' saved [1711/1711]
Info: Checking for prerequisites and creating folders...
mkdir: can't create directory '/tmp/opt': File exists
mkdir: can't create directory '/tmp/opt/bin': No such file or directory
mkdir: can't create directory '/tmp/opt/etc': No such file or directory
mkdir: can't create directory '/tmp/opt/include': No such file or directory
mkdir: can't create directory '/tmp/opt/lib': No such file or directory
mkdir: can't create directory '/tmp/opt/sbin': No such file or directory
mkdir: can't create directory '/tmp/opt/share': No such file or directory
mkdir: can't create directory '/tmp/opt/tmp': No such file or directory
mkdir: can't create directory '/tmp/opt/usr': No such file or directory
mkdir: can't create directory '/tmp/opt/var': No such file or directory
mkdir: can't create directory '/tmp/opt/': No such file or directory
Info: Opkg package manager deployment...
./entware_install_arm.sh: cd: line 27: can't cd to /tmp/opt/bin
--2015-04-25 21:59:56--  http://qnapware.zyxmon.org/binaries-armv7/installer/opkg
Length: 126824 (124K) [text/plain]
Saving to: 'opkg.1'
opkg.1                   100%[====================================>] 123.85K   176KB/s   in 0.7s
2015-04-25 21:59:57 (176 KB/s) - 'opkg.1' saved [126824/126824]
chmod: /tmp/opt/bin/opkg: No such file or directory
./entware_install_arm.sh: cd: line 30: can't cd to /tmp/opt/etc
--2015-04-25 21:59:57--  http://qnapware.zyxmon.org/binaries-armv7/installer/opkg.conf
Length: 146 [text/plain]
Saving to: 'opkg.conf.1'
opkg.conf.1              100%[====================================>]     146  --.-KB/s   in 0s
2015-04-25 21:59:57 (4.50 MB/s) - 'opkg.conf.1' saved [146/146]
./entware_install_arm.sh: cd: line 32: can't cd to /tmp/opt/lib
--2015-04-25 21:59:57--  http://qnapware.zyxmon.org/binaries-armv7/installer/ld-2.20.so
Length: 134404 (131K) [text/plain]
Saving to: 'ld-2.20.so.3'
ld-2.20.so.3             100%[====================================>] 131.25K   188KB/s   in 0.7s
2015-04-25 21:59:58 (188 KB/s) - 'ld-2.20.so.3' saved [134404/134404]
ln: ld-linux.so.3: File exists
--2015-04-25 21:59:58--  http://qnapware.zyxmon.org/binaries-armv7/installer/libc-2.20.so
Length: 1219180 (1.2M) [text/plain]
Saving to: 'libc-2.20.so.3'
libc-2.20.so.3           100%[====================================>]   1.16M   535KB/s   in 2.2s
2015-04-25 22:00:01 (535 KB/s) - 'libc-2.20.so.3' saved [1219180/1219180]
ln: libc.so.6: File exists
Info: Basic packages installation...
./entware_install_arm.sh: line 40: /tmp/opt/bin/opkg: not found
./entware_install_arm.sh: line 41: /tmp/opt/bin/opkg: not found
/tmp/opt/usr/lib/locale/locale-archive: No such file or directory
Info: Congratulations!
Info: If there are no errors above then Entware.arm successfully initialized.
Info: Add /tmp/opt/bin & /opt/sbin to your PATH variable
Info: Add '/tmp/opt/etc/init.d/rc.unslung start' to startup script for Entware.arm services to start
Info: Found a Bug? Please report at https://github.com/zyxmon/entware-arm/issues
When asked for a partition number, you're expected to enter one (1 in your case).
Sent from my Nexus 9 using Tapatalk
Thanks, still no luck though...
[0-1]: 1
Info:  /tmp/mnt/sda2 selected.
* Warning:  Found previous installation, saving...
Info:  Creating /tmp/mnt/sda2/entware.arm folder...
tar: removing leading '/' from member names
--2015-04-26 09:58:30--  http://qnapware.zyxmon.org/binaries-armv7/installer/entware_install_arm.sh
Saving to: 'entware_install_arm.sh.1'
entware_install_arm.sh.1 100%[====================================>]   1.67K  --.-KB/s   in 0s
2015-04-26 09:58:31 (46.7 MB/s) - 'entware_install_arm.sh.1' saved [1711/1711]
mkdir: can't create directory '/opt': File exists
mkdir: can't create directory '/opt/bin': No such file or directory
mkdir: can't create directory '/opt/etc': No such file or directory
mkdir: can't create directory '/opt/include': No such file or directory
mkdir: can't create directory '/opt/lib': No such file or directory
mkdir: can't create directory '/opt/sbin': No such file or directory
mkdir: can't create directory '/opt/share': No such file or directory
mkdir: can't create directory '/opt/tmp': No such file or directory
mkdir: can't create directory '/opt/usr': No such file or directory
mkdir: can't create directory '/opt/var': No such file or directory
mkdir: can't create directory '/opt/': No such file or directory
./entware_install_arm.sh: cd: line 27: can't cd to /opt/bin
--2015-04-26 09:58:31--  http://qnapware.zyxmon.org/binaries-armv7/installer/opkg
Saving to: 'opkg.1'
opkg.1                   100%[====================================>] 123.85K   170KB/s   in 0.7s
2015-04-26 09:58:32 (170 KB/s) - 'opkg.1' saved [126824/126824]
chmod: /opt/bin/opkg: No such file or directory
./entware_install_arm.sh: cd: line 30: can't cd to /opt/etc
--2015-04-26 09:58:32--  http://qnapware.zyxmon.org/binaries-armv7/installer/opkg.conf
2015-04-26 09:58:32 (4.60 MB/s) - 'opkg.conf.1' saved [146/146]
./entware_install_arm.sh: cd: line 32: can't cd to /opt/lib
--2015-04-26 09:58:32--  http://qnapware.zyxmon.org/binaries-armv7/installer/ld-2.20.so
Saving to: 'ld-2.20.so.5'
ld-2.20.so.5             100%[====================================>] 131.25K   189KB/s   in 0.7s
2015-04-26 09:58:33 (189 KB/s) - 'ld-2.20.so.5' saved [134404/134404]
--2015-04-26 09:58:33--  http://qnapware.zyxmon.org/binaries-armv7/installer/libc-2.20.so
Saving to: 'libc-2.20.so.5'
libc-2.20.so.5           100%[====================================>]   1.16M   513KB/s   in 2.3s
2015-04-26 09:58:36 (513 KB/s) - 'libc-2.20.so.5' saved [1219180/1219180]
./entware_install_arm.sh: line 40: /opt/bin/opkg: not found
./entware_install_arm.sh: line 41: /opt/bin/opkg: not found
Info: Add /opt/bin & /opt/sbin to your PATH variable
Info: Add '/opt/etc/init.d/rc.unslung start' to startup script for Entware.arm services to start
admin@RT-AC68U:/tmp/home/root# opkg
-sh: opkg: not found
Make sure you're not using Download Master or Optware, because it's cannot be used at the same time as Entware.
If you have any asusware directory on your USB disk then remove it, reboot, and try again.
Thanks again. It worked by installing Download Master and removing it and then launch the entware script again. Thanks so much for your help!
Can we have Download Master (and Aicloud) and entware together?
Isn't that what the text you quoted answered?
Well, I thought maybe there is Download Master under entware.... Isn't it possible?
Why do we have to install optware to make Download Master work?
Download Master is Asus's own package, which contains the clients (transmission, amule, etc...) along with their custom web interface.. They need some additional packages to provide libraries. For this, they use the Optware packages.
Entware is not compatible because its support packages are of a different version, and Download Master was built by Asus specifically for the package versions used by Optware. That's why you can't mix the two of them.
It's strongly recommended to use Entware with the Entware transmission package rather than Asus's all-in-one Download Master. The Entware package aren't as tightly integrated into the webui, but they will be far more up-to-date.
Thank you for so complete answer!
What about Aicloud, doesn't it need optware?
No, AiCloud is entirely built into the firmware, with no need for any external add-ons.
Is samba also built in?
Everything is built in. Download Master is the only feature that gets downloaded and installed on-demand.
