Entware equivalent Apps
gatorback
I have changed out RT-N16s (Optware) in favor RT-AC68U routers (Entware). The procedure I followed to install Entware is https://www.dd-wrt.com/wiki/index.php/Asus_T-Mobile_Cellspot#Entware_Installation
Optware has excellent apps:
1) pixelserv
2) stophammer
3) asiablock
These apps are nicely described here:
http://www.dd-wrt.com/wiki/index.ph...Service_Explanations.2FConfiguration_Examples
As I understand 2) and 3) are scripts that that use iptables to identify IP addresses to be dropped. Pixelserv is a form of DNS poisoning that redirects targets to a single-pixel webserver.
Are there packages out there for Entware that have the same functionality? Thank you for responding with package names that map to one of the three Optware apps listed above.
@Zirescu: nicely done.
root@ROUTER:/tmp/home/root# ipkg list | grep block
moblock - 0.8-1 - Blocks connections from/to hosts listed in a file in peerguardian format.
moblock may be the answer to finding the asiablock replacement
