Entware installation fails
WillyTP
Hello everybody
I'm trying to install Entware on my RT-AC68U.
However, during the installation process, I get the error below, resulting in Entware not successfully installed.
Is there any workaround?
Info: Basic packages installation...
Downloading http://bin.entware.net/armv7sf-k2.6/Packages.gz
Updated list of available packages in /opt/var/opkg-lists/entware
Installing entware-opt (227000-3) to root...
Downloading http://bin.entware.net/armv7sf-k2.6/entware-opt_227000-3_all.ipk
Installing libc (2.23-8) to root...
Downloading http://bin.entware.net/armv7sf-k2.6/libc_2.23-8_armv7-2.6.ipk
Installing libgcc (7.3.0-8) to root...
Downloading http://bin.entware.net/armv7sf-k2.6/libgcc_7.3.0-8_armv7-2.6.ipk
Installing libssp (7.3.0-8) to root...
Downloading http://bin.entware.net/armv7sf-k2.6/libssp_7.3.0-8_armv7-2.6.ipk
Installing librt (2.23-8) to root...
Downloading http://bin.entware.net/armv7sf-k2.6/librt_2.23-8_armv7-2.6.ipk
Installing libpthread (2.23-8) to root...
Downloading http://bin.entware.net/armv7sf-k2.6/libpthread_2.23-8_armv7-2.6.ipk
Installing libstdcpp (7.3.0-8) to root...
Downloading http://bin.entware.net/armv7sf-k2.6/libstdcpp_7.3.0-8_armv7-2.6.ipk
Installing entware-release (1.0-2) to root...
Downloading http://bin.entware.net/armv7sf-k2.6/entware-release_1.0-2_all.ipk
Installing zoneinfo-asia (2018e-1) to root...
Downloading http://bin.entware.net/armv7sf-k2.6/zoneinfo-asia_2018e-1_armv7-2.6.ipk
Configuring libgcc.
Configuring libc.
Configuring libpthread.
Configuring libstdcpp.
Configuring librt.
Configuring libssp.
Configuring entware-release.
Collected errors:
 * opkg_install_pkg: Package zoneinfo-asia md5sum mismatch. Either the opkg or the package index are corrupt. Try 'opkg update'.
 * opkg_install_cmd: Cannot install package entware-opt.
cp: can't stat '/opt/etc/shells.1': No such file or directory
Info: Congratulations!
Info: If there are no errors above then Entware was successfully initialized.
Info: Add /opt/bin & /opt/sbin to your PATH variable
Info: Add '/opt/etc/init.d/rc.unslung start' to startup script for Entware services to start
Info: Found a Bug? Please report at https://github.com/Entware/Entware/issues
Btw: my zone info would be Europe, however even by installing zoneinfo-europe the installation doesn't finish properly.
Hello everybody
Configuring libgcc.
Configuring libc.
Configuring librt.
Configuring libssp.
Collected errors:
Are you using the built in script to do the install? It doesn't look like it from what you pasted. You have an ext2 or ext3 partition installed?
I confirm I am using the built in script.
USB is formatted as ext4 without journal.
To me looks like the package in Entware repository is broken, since everything else seems to work fine.
I just did the install right when you posted this using the default merlin install script and ext2 using all default settings. The only thing to pick was pressing one for the usb mount point. I then tested it by doing opkg update and opkg upgrade to make sure everything was up to date....
This is the link i followed
https://github.com/RMerl/asuswrt-merlin/wiki/Entware
I just installed Entware with that steps on the link you posted and everything worked without any problems :)
Hello everybody.
I did some testing, and the problem was rather weird.
I connect to the Internet via a Mobile LTE connection, Vodafone Italy operator / ISP.
As suggested HERE, where originally I filed a bug, my ISP probably operates a transparent proxy.
Problem solved by using a VPN.
Hope this may help others :)
