Entware installation on AC66
p71
I am trying to install entware for tranmission.
During the entware installation I am getting massive error messages:
joke71@RT-AC66U:/tmp/home/root# entware-setup.sh
 Info:  This script will guide you through the Entware installation.
 Info:  Script modifies only "entware" folder on the chosen drive,
 Info:  no other data will be touched. Existing installation will be
 Info:  replaced with this one. Also some start scripts will be installed,
 Info:  the old ones will be saved to .entwarejffs_scripts_backup.tgz
 Info:  Looking for available partitions...
[1] --> /tmp/mnt/Sandisk_Pen
 =>  Please enter partition number or 0 to exit
[0-1]: 1
 Info:  /tmp/mnt/Sandisk_Pen selected.
 Info:  Creating /tmp/mnt/Sandisk_Pen/entware folder...
 Info:  Creating /tmp/opt symlink...
ln: /tmp/opt: File exists
 Info:  Creating /jffs scripts backup...
tar: removing leading '/' from member names
 Info:  Modifying start scripts...
 Info:  Starting Entware deployment....
Connecting to wl500g-repo.googlecode.com (173.194.70.82:80)
wget: can't open 'entware_install.sh': File exists
Info: Checking for prerequisites and creating folders...
mkdir: can't create directory '/opt/bin': No such file or directory
mkdir: can't create directory '/opt/etc': No such file or directory
mkdir: can't create directory '/opt/include': No such file or directory
mkdir: can't create directory '/opt/lib': No such file or directory
mkdir: can't create directory '/opt/sbin': No such file or directory
mkdir: can't create directory '/opt/share': No such file or directory
mkdir: can't create directory '/opt/tmp': No such file or directory
mkdir: can't create directory '/opt/usr': No such file or directory
mkdir: can't create directory '/opt/var': No such file or directory
mkdir: can't create directory '/opt/': No such file or directory
Info: Opkg package manager deployment...
./entware_install.sh: cd: line 20: can't cd to /opt/bin
wget: can't open 'opkg': File exists
chmod: /opt/bin/opkg: No such file or directory
./entware_install.sh: cd: line 23: can't cd to /opt/etc
wget: can't open 'opkg.conf': File exists
Info: Basic packages installation...
./entware_install.sh: line 27: /opt/bin/opkg: not found
./entware_install.sh: line 28: /opt/bin/opkg: not found
Info: Cleanup...
Info: Congratulations!
Info: If there are no errors above then Entware successfully initialized.
Info: Found a Bug? Please report at wl500g-repo.googlecode.com
What is the problem? I am using an ext3 formatted USB drive (sandisk 64Gb), SSH, JFFS enabled, formatted.
[0-1]: 1
Info: Cleanup...
reboot your router and start the install again
I don't know why, but it looks like USB drive is read-only.
Filesystem permissions perhaps?
chmod -R 777 /tmp/mnt/Sandisk_Pen/*
