Entware Issue
johnathonm
Hello everyone,
I am running into a weird issue with Entware. I installed it previously without issue but when I ran the AB installer, when trying to install Pixelsev the script is indicating entware is not active. I went to try and reinstall by running entware-setup.sh but the installer hangs in the process.
Is there a way to uninstall entware without having to wipe the device?
Thank you,
J
Here is where it is hanging:
Info: /tmp/mnt/sda1 selected.
Info: Creating /tmp/mnt/sda1/entware folder...
Info: Creating /tmp/opt symlink...
Info: Creating /jffs scripts backup...
tar: removing leading '/' from member names
Info: Modifying start scripts...
Noticed that you have posted a number of issues where scripts that should work are causing problems.
First thought is to check the integrity of the USB device you are using, it can make scripts fail due to mis-reading info from the device.
