Entware on SD card RT-N66U
enr00ted
Hi there,
If this has already been answered I apologize. I have a question. I recently added 2 hard drives to my RT-N66U, 2 USB's. Because I want to have entware installed also, I opened the router and added an sd card. Now, I am able to see and format the card with fdisk. The problem is I don't know how to mount this somewhere like /mnt so I can install entware and make that folder structure.
I don't want entware on any of the drives. Is it possible ? Do I have to modify fstab or something ? Can someone be kind enough to guide me a bit ?
Thank you.
SOLVED.
I reformated the card again using mkfs.ext2 -L ENTWARE /dev/sd.. and somehow after reboot I got it mounted automatically on /tmp/mnt/ENTWARE. Using the wiki on github I installed entware.
