XIII
This weekend @kvic posted a new tool to measure the performance of the USB stick in your router: https://kazoo.ga/benchmark-usb-flash-drives-on-routers/
Turns out my SanDisk Ultra Fit 32GB USB 3.0 Flash Drive is not performing too well: https://kazoo.ga/content/images/iozone-db.txt
What USB drive do you recommend for Entware?
Or maybe: which one do you use now? And can you add your results to the DB?
