pilotboy72
I'm trying to compile Merlin's latest and greatest and I'm getting the following error trying to compile WTFAST:
Having no problems in the build up to this point. Any ideas on how to fix this?
Brian
/bin/bash ./config.status --recheck
running CONFIG_SHELL=/bin/bash /bin/bash ./configure --host=mipsel-linux --build= --host=arm-linux build_alias= host_alias=arm-linux CC=mipsel-uclibc-gcc CFLAGS=-DBCMWPA2 -DBCMQOS -DBCM_DCS -DEXT_ACS -DD11AC_IOTYPES -DPHYMON -DPROXYARP -DTRAFFIC_MGMT -DTRAFFIC_MGMT_RSSI_POLICY -DLINUX26 -DCONFIG_BCMWL5 -DDEBUG_NOISY -DDEBUG_RCTEST -pipe -DBCMWPA2 -funit-at-a-time -Wno-pointer-sign -mtune=mips32r2 -mips32r2 -DRTCONFIG_NVRAM_64K -DLINUX_KERNEL_VERSION=132630 -DRTN66U -D__CONFIG_EMF__ -D__CONFIG_WPS__ --no-create --no-recursion
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for arm-linux-strip... mipsel-uclibc-strip -R .note -R .comment
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking whether make supports nested variables... yes
checking whether to enable maintainer-specific portions of Makefiles... no
checking for arm-linux-gcc... mipsel-uclibc-gcc
checking whether the C compiler works... no
configure: error: in `/home/zzzz/repository/asuswrt-merlin/release/src/router/wtfast/libev-4.20':
configure: error: C compiler cannot create executables
Brian
