Error in Squashfs - RT-AC88U
Jim Gifford
Overnight my AC88U locked up on the GUI, but was able to get this from the SSH session.
Any idea. Running the latest Beta3. Been rock solid till this morning.
[dump prev ops] from 80000000, local len(2850)
_ Reboot message ... _______________________________________________________
SQUASHFS error: Unable to read data cache ent▒U▒52d1a6]
SQUASHFS error: Unable to read page, block 52d1a6, size d054
SQUASHFS error: Unable to read data cache entry [52d1a6]
dhd_detach(): thread:dhd_watchdog_thread:84 terminated OK
dhd_detach(): thread:dhd_watchdog_thread:80 terminated OK
If the message hasn't cleared on another reboot you might need to re-flash the firmware.
This is normal. When you flash a new firmware you end up writing to the partition that is currently in use. So when the router reboots, the filesystem is in an unknown state, which can lead to SquashFS errors. That's why your second line mentions "Reboot message".
After the reboot, the system log is simply telling you what happened on that previous reboot.
