johnathonm
Jul 28 01:27:05 kernel: nf_conntrack: automatic helper assignment is deprecated and it will be removed soon. Use the iptables CT target to attach helpers instead.
Jul 28 01:40:54 kernel: [tdts_shell_ioctl_stat:256] Recv ioctl req with op 2
Jul 28 02:10:54 kernel: [tdts_shell_ioctl_stat:256] Recv ioctl req with op 2
Jul 28 02:40:55 kernel: [tdts_shell_ioctl_stat:256] Recv ioctl req with op 2
Jul 28 03:10:55 kernel: [tdts_shell_ioctl_stat:256] Recv ioctl req with op 2
Jul 28 03:40:55 kernel: [tdts_shell_ioctl_stat:256] Recv ioctl req with op 2
Jul 28 04:10:55 kernel: [tdts_shell_ioctl_stat:256] Recv ioctl req with op 2
Jul 28 04:40:55 kernel: [tdts_shell_ioctl_stat:256] Recv ioctl req with op 2
Jul 28 05:10:55 kernel: [tdts_shell_ioctl_stat:256] Recv ioctl req with op 2
Jul 28 05:40:55 kernel: [tdts_shell_ioctl_stat:256] Recv ioctl req with op 2
Jul 28 06:10:55 kernel: [tdts_shell_ioctl_stat:256] Recv ioctl req with op 2
Jul 28 08:40:55 kernel: [tdts_shell_ioctl_stat:256] Recv ioctl req with op 2
Jul 28 10:46:47 kernel: jffs2: warning: (22051) jffs2_sum_write_data: Not enough space for summary, padsize = -340
xxxx@RT-AC86U-2B48:/tmp/home/root# free
total used free shared buffers cached
Mem: 440436 289824 150612 0 912 24028
-/+ buffers/cache: 264884 175552
Swap: 2097148 0 2097148
xxxxxx@RT-AC86U-2B48:/tmp/home/root# df
Filesystem 1K-blocks Used Available Use% Mounted on
ubi:rootfs_ubifs 79016 65492 13524 83% /
mtd:bootfs 4480 3344 1136 75% /bootfs
mtd:data 8192 608 7584 7% /data
/dev/mtdblock8 49152 2432 46720 5% /jffs
/dev/sda1 58570772 2157308 53271320 4% /tmp/mnt/poop
xxxx@RT-AC86U-2B48:/tmp/home/root# lsmod | grep tdts
tdts_udbfw 45010 0 - Live 0xffffffbffc16f000 (O)
tdts_udb 200764 1 tdts_udbfw, Live 0xffffffbffc2c3000 (PO)
tdts 420025 2 tdts_udbfw,tdts_udb, Live 0xffffffbffca90000 (PO)
bcm_enet 1057744 1 tdts_udbfw, Live 0xffffffbffc366000
pktflow 137055 1 tdts_udbfw, Live 0xffffffbffc33a000 (P)
xxxxx@RT-AC86U-2B48:/tmp/home/root# dmesg | grep tdts
