Error locking /var/lock/cfg_mnt.lock: 28 No space left on device _SOLVED
joe scian
Hi Im in a bit of strife with my RT-AC5300
After a reboot Im getting the following in syslog
pr 20 18:00:08 RT-AC5300-0680 syslog: Error locking /var/lock/cfg_mnt.lock: 28 No space left on device
Apr 20 18:00:08 RT-AC5300-0680 syslog: Error unlocking -1: 9 Bad file descriptor
Apr 20 18:00:08 RT-AC5300-0680 syslog: Error locking /var/lock/cfg_mnt.lock: 28 No space left on device
I issued the following command df -h
joescian@RT-AC5300-0680:/tmp/home/root# df -h
Filesystem                Size      Used Available Use% Mounted on
/dev/root                34.3M     34.3M         0 100% /
devtmpfs                251.4M         0    251.4M   0% /dev
tmpfs                   251.6M    251.5M     24.0K 100% /tmp
/dev/mtdblock4           64.0M     19.4M     44.6M  30% /jffs
/dev/mtdblock4           64.0M     19.4M     44.6M  30% /www/Main_LogStatus_Content.asp
/dev/sda1                13.4G      2.5G     10.2G  20% /tmp/mnt/MY_LINUX2
/dev/mtdblock4           64.0M     19.4M     44.6M  30% /www/QoS_Stats.asp
/dev/sdb1               233.2G     11.5G    221.7G   5% /tmp/mnt/sdb1
/dev/sdd2                 3.6T     46.8G      3.6T   1% /tmp/mnt/TOSHIBA_EXT(1)
/dev/sdc1               931.5G    718.4G    213.1G  77% /tmp/mnt/HD-PCTU3
tmpfs                   251.6M    251.5M     24.0K 100% /www/index_style.css
tmpfs                   251.6M    251.5M     24.0K 100% /www/require/modules/menuTree.js
It shows some filesystems at 100% - any idea how I correct this issue please?
Does a scan report of the top 20 largest files on '/tmp/' give any clue?
du -axh /tmp/ | sort -nr | head -n 20
more issues here
uiDivStats: Starting Diversion statistic generation...
/opt/bin/grep: write error: No space left on device
echo: write error: No space left on device
awk: cmd. line:1: Division by zero
awkNR: /tmp/uidivstats/div-bwl: No such file or directory
head: standard output: No space left on device
uiDivStats: Diversion statistic generation completed successfully!
im getting blocked by snbforums when i try and post output
804.0K /tmp/bwdpi
612.0K /tmp/var
456.0K /tmp/etc
396.0K /tmp/bwdpi/bwdpi.rule.db
288.0K /tmp/bwdpi/bwdpi.devdb.db
Hmm, you are look for files sizes in MB/GB.
Try the command again, but remove 'x'.... just in case
Martineau
I think i found it - it may have been a corruption on my Toshiba 4Tb drive hanging off the Router. When I initially ran your command one of the outputs was a 250 MByte file /tmp/mnt/TOSHIBA_EXT/Better_Call_Saul.mkv - and another 250Mbyte file pointing to /tmp/mnt/TOSHIBA_EXT(1)/Better _Call_Saul.mkv. I deleted both of these and now when I run
du -axh /tmp/ | sort -nr | head -n 20 - there is no reference to /tmp/mnt/TOSHIBA_EXT and the largest file is 804.0Kn/tmp/bwdpi. Or - I must have put the download file ( 250MBYTE ) in the wrong directory space when I was experimenting with aria2 Torrent downloader. Anyway
thank you very very much for your expert guidance - it was also extremely crazy not being able to post the full output because snb was continually blocking me - something the site filter is not happy with
@joe scian, next time use pastebin.com to post your logfile. :)
