I bought some cat5e from monoprice... I have an amped wireless ap300 access point, but when I attach the cable, the device freezes and the power lights just flashes. This is what amped told me:
PROBLEM
The Pro Access Point is not functioning and the Power LED keeps blinking.
SOLUTION
a. The network (Ethernet) cable you are using is not compatible with the Pro Access Point. Replace the
network cable between the PoE Adapter and your router/switch with a Non-PoE cable.
Tip: How to check whether your cable is a PoE cable or a Non-PoE cable:
Check the connector tip of the network cable to see if there are 4 wires or 8 wires.
Non-PoE cables have only 4 wires.
b. If you have a computer or network device attached to the LAN port of the Pro Access Point, check that the
cable is a Non-PoE cable. Some unsupported PoE devices may cause power conflicts with the Pro Access Point."
so, I looked through my box of extra cables, and think I found a short ethernet cable which looks like it has only 4 wires in it (not sure where I got it, from a modem maybe?). anyway, the AP worked with the 4-wire cable. But when I search the web, looking for, say a 100ft ethernet cable, they all seem to be 8 wire? does 4 wire exist?
PROBLEM
SOLUTION
